德州仪器
直播中
曹玥
7年用户 224经验值
私信 关注
[问答]
能推荐合适的相机最小尺寸吗
嗨罗伯特,你能推荐一下吗?
合适的相机最小尺寸,H264压缩由Raspberry Pi3连接和控制?
适用于Raspberry Pi 3 B控制和相机命令的软件?
谢谢
彼得
以上来自于谷歌翻译
以下为原文
        Hi Robert, can you please recommend
  • suitable camera smallest footprint, H264 compression to be connected and controlled by Raspberry Pi3?
  • Suitable software for Raspberry Pi 3 B control and command of camera(s)?
thank you
Peter
回帖(5)
郭雨桐
2018-10-23 13:27:09
@odenplan,
我见过的大多数h264相机都是以u***为基础的。
这是我们通过相机界面连接到Pi的Raspbery Pi相机列表,因此压缩必须在Pi上进行:
https://www.digikey.com/products/en/development-boards-kits-programmers/evaluation-boards-expansion-boards-daughter-cards/797?k=Raspberry+Pi+Camera&k=&pkeyword=
覆盆子+ PI +相机及安培; pv1989 = 0&安培; FV = ffe0031d&安培;数量= 0&安培; ColumnSort = 0&安培;页= 1&安培; pageSize的= 25
PINOIR似乎是最有用的:
https://www.digikey.com/product-detail/en/raspberry-pi/913-2673/1690-1012-ND/6152811
Doc's在这里:https://projects.raspberrypi.org/en/projects/getting-started-with-picamera
问候,
以上来自于谷歌翻译
以下为原文
        @odenplan,
Most of the h264 camera’s I’ve seen are u*** based.
Here is our list of Raspbery Pi cameras that connect to the Pi over the camera interface, so the compression would have to be done on the Pi:
https://www.digikey.com/products/en/development-boards-kits-programmers/evaluation-boards-expansion-boards-daughter-cards/797?k=Raspberry+Pi+Camera&k=&pkeyword=Raspberry+Pi+Camera&pv1989=0&FV=ffe0031d&quantity=0&ColumnSort=0&page=1&pageSize=25
The PINOIR seems to be the most useful:
Doc’s are here: https://projects.raspberrypi.org/en/projects/getting-started-with-picamera
Regards,
举报
刘悦竹
2018-10-23 13:34:19
嗨,
只是为了让你明白
如果你应该选择这个Zerocam。
它有一条为Pi Zero制造的更细的电缆。
您无法直接将其连接到Pi3B。
问候,
迈克尔
以上来自于谷歌翻译
以下为原文
        Hi,
Just to make you aware.
If you should select this  Zerocam.
It has a thinner cable made for the Pi Zero. You can’t directly connect it to the Pi3B.
Regards,
Michael
举报
刘悦竹
2018-10-23 13:51:47
刚刚找到了Pi3B的版本
问候,
迈克尔
以上来自于谷歌翻译
以下为原文
        Just found a Version for the Pi3B
Regards,
Michael
举报
张婧怡
2018-10-23 14:04:34
嗨迈克尔
这台相机有H264压缩吗?
谢谢
彼得
以上来自于谷歌翻译
以下为原文
        Hi Michael
Does this camera have H264 compression?
Thank you
Peter
举报
更多回帖
