是德科技
直播中
宋宾
8年用户 208经验值
私信 关注
[问答]
34461A丢失USB连接
当它插入USB端口时,我再也看不到我的DDM作为USB设备了。
我的Windows设备管理器将DDM显示为便携式设备,但不是USB设备。
这适用于两台PC - 一台Windows 7和一台Windows 10.我直接连接到PC,而不是通过集线器连接。
它以前工作。
我的DSO-X-2022A工作正常。
我该怎么办?
戈登
以上来自于谷歌翻译
     以下为原文
  I can no longer see my DDM as a USB device when it is plugged into a USB port.  My Windows Device Manager shows the DDM as a portable device, but not as a USB device.  This is true for two PCs - one Windows 7 and one Windows 10.  I am connecting directly to the PCs, not via a hub.  It was working previously.  My DSO-X-2022A works fine.  What should I do?
Gordon
回帖(2)
杨梅
2018-10-22 16:31:55
您好,您可能已从前面板关闭了USBTMC。
EZ文件访问已打开,即便携式设备。
我对34461A前面板不太熟悉,或者我会按下按钮,但我肯定会探测并找到你的USB设置并确保它在仪器上正确配置。
以上来自于谷歌翻译
     以下为原文
  Hello,
You probably have  USBTMC turned off from the front panel. EZ file access is turned on, which is that Portable Device.  I'm not overly familiar with the 34461A front panel or I would provide you the button presses, but I would definitely probe around and find your USB settings and make sure it is configured correctly on the instrument.
举报
宋宾
2018-10-22 16:43:16
EZ文件访问已打开,即便携式设备。
谢谢。
修好了。
我不知道它是如何被关闭的,因为我安装了DDM后,我已经远离该菜单。
另一位快乐的是德科技用户和支持论坛用户。
以上来自于谷歌翻译
     以下为原文
  Thanks.  That fixed it.
I have no idea how it got turned off as I have been nowhere near that menu since I installed the DDM.
Another happy Keysight user and Support Forum user.
举报
更多回帖
