赛灵思
直播中
茹然
8年用户 183经验值
私信 关注
[问答]
连接到制作的IP的嵌入式系统要通过XPS使用用户IP吗
我已经使用XPS对我所做的IP进行了高级测试。
,在BSB项目中首次插入DDR3 Xilinx IP时,单击“导出设计”,当我升级Syn时,出现类似如下的PaR,错误消息。
,,它继续没有特别改变的部分,为什么以下消息:你出来了吗?
错误信息
错误:包装:2811  - 定向包装无法遵守用户设计约束(LOC = R7),这要求将下面列出的符号组合打包到单个IOB组件中。
定向包是不可能的,因为:不止一个垫符号。
涉及的符号是:PAD符号“MCB_DDR3_zio”(填充信号= MCB_DDR3_zio)TBUF符号“MCB_DDR3 / MCB_DDR3 / mcb_ui_top_0 / mcb_raw_wrapper_inst / gen_term_calib.mcb_soft_ calibration_top_inst / gen_zio.IOBUF_ZIO / OBUFT”(控制信号= MCB_DDR3 / MCB_DDR3 / mcb_ui_top_0 / mcb_raw_wrapper_inst /
gen_term_calib.mcb_soft_c alibration_top_inst / ZIO_TOUT)BUF符号 “MCB_DDR3 / MCB_DDR3 / mcb_ui_top_0 / mcb_raw_wrapper_inst / gen_term_calib.mcb_soft_ calibration_top_inst / gen_zio.IOBUF_ZIO / IBUF”(输出信号= MCB_DDR3 / MCB_DDR3 / mcb_ui_top_0 / mcb_raw_wrapper_inst / gen_term_calib.mcb_soft_c alibration_top_inst / ZIO_IN)PAD符号
“MCB_DDR3_dram_ras_n”(填充信号= MCB_DDR3_dram_ras_n)
另外,我正在尝试连接到我制作的IP的嵌入式(Microblaze)系统。
要通过XPS使用用户IP,还是只能通过“创建IP”申请?
,,当通过“创建IP”I连接时,它是写一个IPIC,但我想在没有写入IPIC的情况下使用PLB接口和AXI给Direct。
,,它可以告诉它该怎么办?
我希望你能理解我不擅长英语。
谢谢
以上来自于谷歌翻译
以下为原文
I have advanced test the IP that I have made using the XPS. ,Click the " Export Design " as soon as you Insert the DDR3 Xilinx IP for the first time in BSB project, When I promoted Syn, the PaR, Error message similar to the following appears . ,, It proceeded without the part was changed in particular, why the following message: Are you coming out ?
Error Message
ERROR:Pack:2811 - Directed packing was unable to obey the user design
constraints (LOC=R7) which requires the combination of the symbols listed
below to be packed into a single IOB component.
The directed pack was not possible because: More than one pad symbol.
The symbols involved are:
PAD symbol "MCB_DDR3_zio" (Pad Signal = MCB_DDR3_zio)
TBUF symbol
"MCB_DDR3/MCB_DDR3/mcb_ui_top_0/mcb_raw_wrapper_inst/gen_term_calib.mcb_soft_
calibration_top_inst/gen_zio.IOBUF_ZIO/OBUFT" (Control Signal =
MCB_DDR3/MCB_DDR3/mcb_ui_top_0/mcb_raw_wrapper_inst/gen_term_calib.mcb_soft_c
alibration_top_inst/ZIO_TOUT)
BUF symbol
calibration_top_inst/gen_zio.IOBUF_ZIO/IBUF" (Output Signal =
alibration_top_inst/ZIO_IN)
PAD symbol "MCB_DDR3_dram_ras_n" (Pad Signal = MCB_DDR3_dram_ras_n)
In addition , I'm trying to connect to the Embedded (Microblaze) System the IP I made .
To use the IP of User by XPS, or will be able to apply only through the " Create IP " ? ,, When connecting through the "Create IP " I , and it is to write a IPIC , but I want to give to the Direct using the PLB Interface and AXI without writing IPIC. ,, It can be given to tell it how to do ?
I would like you to understand me not good at English.
Thx
回帖(1)
李铃华
2018-10-19 14:41:23
要解决此问题,请修改生成的UCF以将系统控制引脚移动到不冲突的IO。
您还可以尝试使用最新版本迁移设计
谢谢和RegardsBalkrishan -----------------------------------------------
---------------------------------------------请将帖子标记为
一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。
以上来自于谷歌翻译
以下为原文
To work around this issue, modify the generated UCF to move the system control pins to non-conflicting IOs.
You can also try migrating the design with latest version
 Thanks and Regards
Balkrishan
Please mark the post as an answer "Accept as solution" in case it helped resolve your query.
Give kudos in case a post in case it guided to the solution.
举报
更多回帖
