谁能帮我?
我们的型号是E5247A。
我想测试我的VNA随时间的稳定性。
VNA已经升温,至少3小时。
以下是我的setup-parameter。
1. 15dBm源功率2.1.5KHz分辨率BW 3.Span 60MHz,中心2.06GHz 4.6401扫描点5.Full 2端口Cal我做了什么:连接两个VNA端口和Bullet Adapter。
并存储S21(数据)到内存,显示内存数据。
开始时,内存和数据之间的差异大约为-80dB。
2小时后,差异增加到-50或-55dB(甚至-45dB),这意味着VNA漂移很多。
但我重复了相同的过程,但将两个VNA端口与45dB衰减器连接在一起。
最初,内存和数据之间的差异大约是-110dB。
2小时后,差异增加到-90dB左右。
我在想,这是正式的吗?
与45dB衰减器测试相比,为什么VNA漂移很多?
提前致谢。
以上来自于谷歌翻译
以下为原文
Can any one help me?
Our model is E5247A. I want to test the stability of my VNA over
time. The VNA already w
ARMs up, at least 3hours. The following is my setup-parameter.
1. 15dBm source power
2.1.5KHz resolution BW
3.Span 60MHz, center at 2.06GHz
4.6401 sweep points
5.Full 2 port Cal
What i did :
connect two VNA port together with Bullet Adapter. And storage S21 (the data) to memory, show the memory-data. At the beginning, the difference between memory and data is around -80dB. 2hour later, the difference increases to -50 or -55dB(even -45dB), meaning VNA drift a lot.
But I repeated the same process, but connect two VNA port together with 45dB attenuator. And storage S21 (the data) to memory, show the memory-data. At the beginning, the difference between memory and data is around -110dB. 2hour later, the difference increases to around -90dB.
I was wondering, is this formal? Why VNA drift a lot with Bullet Adapter compared with 45dB attenuator test?
Thanks in advance.
