Cypress技术论坛
直播中
李高歌
8年用户 220经验值
私信 关注
[问答]
MQTT打开连接失败
你好,
我有一个星云1 IOT开发套件,我试图连接到AWS板。我正在使用Waice Studio 6.1中的AWSIOT演示文件夹。我已经在AWS上建立了一个帐户,并创建了一个证书以及一个东西和策略。我所面临的问题是在资源& GT;Apple & GT;AWSUT.Go.AWS.CONtiON.HTML中发现的WORD AWS IOT服务不起作用。如何更新文件CeleT.CER、PrimKE.CER和ROOTCA.CER?我相信没有正确的文件给我这个MQTT打开连接失败的错误。
谢谢,
里克
以上来自于百度翻译
     以下为原文
  Hello,
I have a Nebula 1.0 IoT development kit and I'm attempting to connect the board onto AWS. I am using the awsiot demo folder in WICED-Studio 6.1. I have already setup an account on AWS and created a certificate as well as a Thing and Policy. The problem I'm having is the WICED AWS IOT Service that is found in the resources>apps>awsiot>aws_config.html does not work. How do I update the files client.cer, privkey.cer, and rootca.cer? I believe not having the correct files is giving me this MQTT Opening Connection Failed Error.
Thanks,
Rick
回帖(7)
李高歌
2018-10-18 15:54:44
受到警告
提示: 作者被禁止或删除 内容自动屏蔽
举报
h1654155275.5741
2018-10-18 16:02:46
感谢更新DV89991414111
你也应该接触到你的当地未来分支,因为他们可以为星云板提供额外的软件/硬件支持。
以上来自于百度翻译
     以下为原文
  Thanks for the update dv89_9_1490111
You should also reach out to your local Future branch as they can provide additional software/hardware support for the Nebula board.
举报
王璐
2018-10-18 16:09:13
引用: wonick 发表于 2018-10-18 10:05
感谢更新DV89991414111
HI成功连接到AWS后,您如何配置。代码使终端能够显示来自不同扩展板的数据(例如温度等)。
以上来自于百度翻译
     以下为原文
  hi after successful connect to the aws, how do you config. the code at WICED to enable the terminal to show the data eg. temperature,etc from the different expansion boards.
举报
李正茂
2018-10-18 16:27:40
以上来自于百度翻译
你好!你的意思是你想在未来的AWS项目中加入传感器板代码吗?您需要自己把驱动程序代码导入项目中。驱动程序和示例代码是由未来提供的。
以上来自于百度翻译
     以下为原文
  Hi mingyang.ang_3244646! Do you mean you want to add in the sensor board code that Future has written into the AWS project? You would need to bring the driver code into the project yourself. The drivers and example code is provided by Future.
举报
更多回帖
