嗨,异步控制信号的详细信息在XST综合报告的“异步控制信号信息”部分中列出。有关其他详细信息,您可以查看RTL或打开合成设计并跟踪控制信号.Regards,Achutha
-------------------------------------------请注意 - 请标记答案
如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------
以上来自于谷歌翻译
以下为原文
Hi,
The details of Asynchronous control signals is listed in the XST synthesis report under the section "Asynchronous Control Signal Information.
For other details you may either have look at the RTL or open the synthesized design and trace the control signals.
Regards,
Achutha---------------------------------------------------------------------------------------------
Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful.
Give Kudos to a post which you think is helpful and reply oriented.
以上来自于谷歌翻译
以下为原文
Hi,
Regards,
举报
