嗨,大家好!
我遇到了一个小问题。
我在Fieldfox N9912A上以NA模式工作,我需要跟踪我的频率和dB值如何随着测试
电路中的变化而变化。
所以我手动设置了跟踪标记,然后将x和y值编程为读入数组并保存到Excel文件中。
我遇到的问题是Y标记正在被正确读取和保存,但是X值(Freq)只是读出并连续保存相同的值。
我正在使用CALCULATE:SELECTED:MARKER1:Y?
计算得到:选择:MARKER1:X?
一个工作,另一个不工作!
正在读取的值对于y而不是x是正确的。
请帮忙!
我在命令行中附上了我的程序结果的屏幕截图。
命令行中的输出不在分析仪上,显示随后保存到数组中的值。
因此保存很好但是使用上面的命令读取跟踪标记的X值是不正确的。
编辑:hark于2016年3月14日上午5:54
编辑:hark于2016年3月14日上午5:58
以上来自于谷歌翻译
以下为原文
Hi Guys!
I'm stuck with a little problem. I am working in NA mode on Fieldfox N9912A and I need to track how my frequency and dB value changes with condi
tions I change in my test circuit. So I have set a tracking marker manually and then programmed the x and y values to be read into an array and saved into an Excel file. The problem I have is the Y marker is being read and saved correctly as it changes but the X value(Freq) just reads out and saves the same value continuously.
I am using
CALCULATE:SELECTED:MARKER1:X?
One works, the other does not! The values being read are correct for y but not the x.
Please help! I have attached a screenshot of my program results in command line. The output in the command line is off the analyser showing the values which are then saved into the array. So saving is fine but reading of the X value of the tracing marker is incorrect using the above command.
Edited by: hark on Mar 14, 2016 5:54 AM
Edited by: hark on Mar 14, 2016 5:58 AM
附件
