Yocchi
只有这么远,你可以去,你真的不能得到14位的两个7位DAC。在纸上你可能能够,但是硬件的绝对DNL没有改变,更坏的情况是7个比特的1个LSB,8个比特的2个LSB,9个比特的4个LSB等等。你可以得到一个可用的9位,但是DNL可能超过你能容忍的。
Stobe模式,我一直要求它,但因为这些DAC主要用于帽子感,所以觉得不需要它。如果我有我的方式,我们所有的DAC都会有一个双缓冲闪存模式。我喜欢PSoC 3/5中的VIDACs,因为它们的灵活性,选通/直接模式,电压/电流,以及DAC总线!
作记号
以上来自于百度翻译
以下为原文
Yocchi,
There is only so far you can go and you really can't get 14-bits out of two 7-bit DACs. On paper you might be able to, but the absolute DNL of the hardware does not change, worse case it is 1 LSB for 7 bits, 2 LSBs for 8 bits, 4 LSBs for 9 bits, etc. You may be able to get a usable 9-bits, but the DNL may be more than you can tolerate.
Stobe mode, I keep asking for it, but since these DACs were primarily used for Cap Sense, it was felt there wasn't a need for it. If I had my way, ALL of our DACs would have a double-buffered strobe mode. I love the viDACs in PSoC 3/5 because of their flexibility, strobe/direct mode, voltage/current, and the DAC Bus!
Mark
Yocchi
作记号
以上来自于百度翻译
以下为原文
Yocchi,
Mark
举报
