工程资源中心
直播中
韩禹
8年用户 189经验值
私信 关注
[MCU]
高度可用的高速计数器和脉冲序列输出参考设计包括BOM及层图
            This ti design provides a reference solution (firmware and test platform) for two different industrial IO functions related to motion control: High Speed Counter (HSC) and Pulse Train Output (PTO). The design is based on a microcontroller platform that is suitable for use in industrial applications  (...)
主要特色
  • High speed (up to 400KHz) 32-bit HSC counter with two counter input pins, four auxiliary input pins, two input  capture registers, and two compare output pins
  • PTO  generates output pulse trains and trapezoidal profiles up to 100KHz with 9.1ns resolution
  • Count/Dir, Clockwise/Counter Clockwise, and  (...)
更多回帖
