英特尔
直播中
杨静
8年用户 1526经验值
私信 关注
[问答]
VLC快速最小/最大视频会导致Intel GPU驱动程序崩溃
我有以下问题,通过在VLC中快速最小/最大视频流,我可以通过高机会重现,崩溃英特尔GPU驱动程序。
我认为这需要主要在英特尔方面进行报告,而不是VLC或MS,因为像VLC这样的用户空间应用程序即使是VLC中的错误也不应该使视频驱动程序崩溃,对吧?
Windows显示这些崩溃:
我没有任何其他问题,游戏,prime95稳定,其他媒体播放器,如MPC,Chrome等。
它恰好发生在VLC和快速最小/最大视频动作上。
来自VLC的日志条目,当它发生时说:
主要警告:图片太晚无法显示(缺少31毫秒)
主要警告:图片太晚无法显示(缺少14毫秒)
direct3d11错误:SwapChain存在失败。
(HR = 0x887A0005)
主要警告:图片太晚无法显示(缺少8毫秒)
(HR = 0x887A0005)
(HR = 0x887A0005)
(HR = 0x887A0005)
(HR = 0x887A0005)
(HR = 0x887A0005)
(HR = 0x887A0005)
(HR = 0x887A0005)
(HR = 0x887A0005)
(HR = 0x887A0005)
(HR = 0x887A0005)
(HR = 0x887A0005)
(HR = 0x887A0005)
错误代码0x887A0005似乎意味着DXGI_ERROR_DEVICE_REMOVED,这显然是无稽之谈。
笔记本电脑是配备Optimus的2 GPU设备。
所以这似乎是驱动程序问题或Windows错误。
以上来自于谷歌翻译
以下为原文
I have the following issue, that I can mostly with high chance reproduce, crashing the Intel GPU driver, by quickly min/max a video stream in VLC. I think this needs to be reported mostly at Intel's side, not VLC or MS, because a userspace app like VLC shouldnt be able to crash the video driver even if it was a bug maybe in VLC, right?
Windows show these for the crash:
I have no other issue anywhere, while gaming, prime95 stability, other media players like MPC, Chrome ect. It just happens with VLC and a fast min/max video action.
A log entry from VLC, when it happens says:
main warning: picture is too late to be displayed (missing 31 ms)
main warning: picture is too late to be displayed (missing 14 ms)
direct3d11 error: SwapChain Present failed. (hr=0x887A0005)
main warning: picture is too late to be displayed (missing 8 ms)
Error code 0x887A0005 seems to mean DXGI_ERROR_DEVICE_REMOVED, which is obviously nonsense. The laptop is a 2 GPU device with Optimus. So this seems to be a driver issue or a Windows bug.
回帖(3)
汤宇
2018-10-17 12:05:54
Helloklumsch,
感谢您的发表。
根据您收到的错误消息,您可以尝试解决一些建议。
在下面找到它们。
打开VSynch Switch关闭抗锯齿功能完全删除计算机中的两个驱动程序,以确保安装干净的视频驱动程序。
在“控制面板”的“电源选项”中将Windows电源设置设置为“高性能”。
运行http://www.microsoft.com/en-us/download/details.aspx?id=35以修复损坏的DirectX文件。
如果您提供了下载英特尔®系统支持实用程序for Windows *报告,我可以帮助您获得正确的驱动程序和清洁卸载和重新安装的步骤。
艾米C.
英特尔客户支持技术人员
根据与英特尔公司的合同
以上来自于谷歌翻译
以下为原文
Hello klumsch,
Thank you for posting.
Based on the error message you are getting, there are a couple of suggestions you can try to address it. Find them below.
  • Turn on VSynch
  • Switch off Anti-Aliasing
  • Completely remove both drivers in your computer to ensure a clean video driver installation.
  • Set Windows power settings to High performance in the Power Options in Control Panel.
  • Run the http://www.microsoft.com/en-us/download/details.aspx?id=35 to possibly fix corrupted DirectX files.
If you provide your Download Intel® System Support Utility for Windows* report, I can help to get the right driver and steps for the clean un-install and re-install.
Amy C
Intel Customer Support Technician
Under Contract to Intel Corporation
举报
李玉鑫
2018-10-17 12:23:10
引用: jerry1978 发表于 2018-10-17 14:36
Helloklumsch,
感谢您的发表。
我安装了最新的驱动程序,包括Nvidia和Intel(6323)。
Windows 10也是最新的10月更新1809.崩溃只发生在DX11视频加速,而不是DXVA。
VLC.exe***入到Nvidia面板中以便始终在Intel GPU上运行,这也是我的默认设置btw(在iGPU上运行,并且只是在dGPU上排除了标题)。
当然,默认情况下VSync是开启的,因为有一段时间英特尔不再使用全局AA关闭选项,所以我只是使用了默认选项。
以上来自于谷歌翻译
以下为原文
I have the latest drivers installed, both Nvidia and Intel (6323). Windows 10 is also latest October update 1809. The crash just happens with DX11 video acceleration, not DXVA. VLC.exe is inserted into Nvidia panel to always run on Intel GPU, which is also my default setting btw (run all on iGPU, and just excluded titles on dGPU). VSync is on of course as per default, A Global AA off option is not possible anymore since some time, Intel removed this for whatever reason, so I just use the default options.
举报
汤宇
2018-10-17 12:29:25
根据您的描述,行为仅在最小/最大视频动作时发生。
因此,行为可能与此特定软件/功能隔离。
您是否尝试使用他们的支持来填写错误报告://trac.videolan.org/?
我还建议检查他们的论坛:https://forum.videolan.org/
艾米C.
英特尔客户支持技术人员
根据与英特尔公司的合同
以上来自于谷歌翻译
以下为原文
Based on your description, the behavior only occurs when in fast min/max video action. So, the behavior might be isolated to this specific software/feature. Have you tried filling a bug report with their support https://trac.videolan.org/? I would also recommend to check their forums: https://forum.videolan.org/
Amy C
举报
更多回帖
