beachbum2:我们会尽力提供您所需的信息。
作为第一个建议,在进行任何更改之前,请备份存储在PC上的所有重要信息。
我们建议安装由电路板制造商提供的英特尔®RST版本,在本例中为华硕,因为它们将为您的平台提供正确的版本。我查找了您的电路板型号,并且华硕Z87有不同的结果
主板,如果你提供它的具体型号,我们总是可以尝试寻找与之兼容的英特尔®RST版本:https://www.asus.com/search/results.aspx?SearchKey =华硕%
20Z87
由于您使用的是Windows®10,并且主板可与英特尔®Z87芯片组配合使用,因此我们始终可以尝试安装英特尔®通用RST版本14.8.0.1042:https://downloadcenter.intel.com/download/25165/Intel-Rapid
- 存储 - 技术 - 英特尔RST-用户界面和驱动程序?产品= 55005
此致,Alberto R.
英特尔客户支持技术人员与英特尔公司签订合同
以上来自于谷歌翻译
以下为原文
beachbum2: We will do our best to provide the information you are looking for.
As a first suggestion, before doing any changes, please back up any important information stored on the PC.
We recommend to install the Intel® RST version provided by the manufacturer of the board, in this case ASUS, since they will provide the proper version for your platform.
I looked for the model of your board and there are different results for the Asus Z87 motherboard, if you provide the specific model of it, we can always try to look for the Intel® RST version that will be compatible with it:
https://www.asus.com/search/results.aspx?SearchKey=Asus%20Z87
Since you are using Windows® 10 and the motherboard works with Intel® Z87 Chipset, we can always try to install the Intel® generic RST version 14.8.0.1042:
https://downloadcenter.intel.com/download/25165/Intel-Rapid-Storage-Technology-Intel-RST-User-Interface-and-Driver?product=55005
Regards,
Alberto R.
Intel Customer Support Technician
Under Contract to Intel Corporation
20Z87
此致,Alberto R.
以上来自于谷歌翻译
以下为原文
Regards,
Alberto R.
举报
