如果您使用良好的屏蔽电缆并且DUT也是屏蔽的,那么它应该不是问题。
我们一直在VNA周围使用无线鼠标,从来没有遇到过问题。
如果您的测量设置的任何部分未被屏蔽,并且您正在使用其中一种宽带测量(如噪声系数或频谱分析仪模式(如果您的VNA恰好是PNA或PNA-X),那么您可能会发现问题。
在这种情况下,您可以看到附近任何发射器的杂散信号,其频率接近您正在测量的频段。
以上来自于谷歌翻译
以下为原文
if you are using good shielded cables and the DUT is also shielded, then it shouldn't be a problem. we use wireless mice around our VNAs all the time and never had a problem. where you might see a problem is if any part of your measurement setup is unshielded and you are using one of the wideband measurements like Noise Figure or Spectrum Analyzer mode (if your VNA happens to be a PNA or PNA-X). in situations like that you could see spurious signals from any emitter nearby that has frequencies close to the band you are measuring.
以上来自于谷歌翻译
以下为原文
举报
