Microchip
直播中
柳杨
8年用户 215经验值
私信 关注
[问答]
怎么在DSPIC30F4011中实现PID
我想在DSPIC30F4011中实现PID,可以帮助我如何用C实现集成。
以上来自于百度翻译
      以下为原文
    I want to implement PID in dspic30f4011, Can any one help me how do i can implement integration using C.
回帖(3)
张蕾
2018-10-16 08:48:26
Himaybe不是“集成”而是“AcMUTE”。给定函数的“积分”是由函数图、x轴和积分极限所限制的区域。如果函数是一个变化的电压,则只需要在很小的时间间隔对它进行采样(ADC),并添加(AcMutt)ADC结果。PS//E.维基百科. org/.
以上来自于百度翻译
      以下为原文
    Hi
Maybe you don't "integrate" but "acumulate" instead.
The "integral" of a given function is the area limited by the function graph, the "X" axis and the integration limits.
If the function is a varying voltage, you just need to sample it (ADC) at small intervals and add (acumulate) the ADC results.
https://en.wikipedia.org/...ral_approximations.svg
HIH
Best regards
Jorge
举报
徐依妮
2018-10-16 09:04:59
怎样才能找到一个信号的微分。
以上来自于百度翻译
      以下为原文
    How can I find D differentiation of a signal.
举报
张蕾
2018-10-16 09:11:58
再次回到基础!在给定的点上函数的导数表示在该点上函数的切线的斜率。因此,在2个非常接近的点上得到函数的值,并计算这2点通过的行的斜率。http://e.维基百科。org/wiki/文件:TangeTeNoto-Ay曲线。可变电压(V)信号只得到2个ADC读数,用非常小的时间(t)分隔,计算(V2-V1)/(T2-T1)。
以上来自于百度翻译
      以下为原文
    Hi
Back to the basics again!
The derivative of a function at a given point represents the slope of the tangent to the graph of the function at that point.
So, got the value of the function in 2 very close points and calculate the slope of the line passing by those 2 points.
https://en.wikipedia.org/wiki/File:Tangent_to_a_curve.svg
For a varying voltage (V) signal just get 2 ADC readings separated by a very small amount of time (t) and calculate (V2-V1)/(t2-t1).
Gosh...looks like I'm back in high school.
Best regards
Jorge
举报
更多回帖
