嗨,
这看起来像许可证问题,并且未正确设置许可证路径。
许可证检查在Map中完成,因此综合没有任何问题。
您使用的是webpack许可证吗?
使用Webpack许可证不支持Virtex 7设备。
如果您使用的是webpack以外的许可证,请确保将许可证enivronmental变量点设置为许可证文件
例:
XILINXD_LICENSE_FILE = C:。Xilinx Xilinx.lic
-------------------------------------------请注意 - 请标记答案
如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------
以上来自于谷歌翻译
以下为原文
Hi,
This looks like a license issue and the license paths are not set properly.
The license check is done in Map ,so the synthesis doesn't have any problem.
Are you using a webpack license?
Virtex 7 devices are not supported using Webpack license.
If you are using license other than webpack , make sure you set the license enivronmental variable point to the license file
example:
XILINXD_LICENSE_FILE = C:.XilinxXilinx.lic
Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful.
Give Kudos to a post which you think is helpful and reply oriented.
嗨,
您使用的是webpack许可证吗?
例:
以上来自于谷歌翻译
以下为原文
Hi,
example:
举报
