是德科技
直播中
刘文明
8年用户 180经验值
私信 关注
[问答]
Command Expert在模拟模式下无响应
嗨,希望这是“命令专家”的正确论坛
我安装了最新的“Command Exert”(Keysight_Instrument_Control_Bundle_8.2015.exe),启动程序后,我可以看到两个默认乐器N6700和SCPI-99。
现在当在SIMULATED模式下连接到两个乐器的以太时,我在执行查询时无法获得任何结果/响应。
例如,选择命令* IDN?
并单击执行并单击播放序列不会给出任何结果。
问题:我做错了什么?
在模拟模式下进行查询时如何获得结果/响应?
是否可以在没有连接物理仪器的模拟模式下独立运行Command Expert?
对此提出任何反馈......在此先感谢。
以上来自于谷歌翻译
     以下为原文
  Hi,
hope this is correct forum for "Command Expert".
I have installed latest "Command Exert" (Keysight_Instrument_Control_Bundle_8.2015.exe) and when started the program I can see the two default instruments N6700 and SCPI-99.
Now when connect to ether of the two instruments in SIMULATED mode I can't GET ANY at all result/response when doing a query.
For instance, selecting command *IDN? and clicking perform and also clicking Play Sequence give no result what so ever.
QUESTIONS:
What am I doing wrong ? How can I get result/response when doing a query in simulated mode ?
Isn't it possible to run Command Expert standalone in simulated mode with no physical instrument connected ?
Appriciate any feedback on this....
Thanks in advance.
回帖(1)
张文琳
2018-10-15 11:18:13
嗨,Command Expert中的SIMULATED模式不会给你任何结果,这个模式只是在编辑序列时将连接保留为空白,完成序列后,你必须找到仪器的实际地址并修改连接步骤
但是,您可以使用某些软件应用程序来模拟仪器并将Command Expert连接到这个假仪器,然后您可以获得一些数据响应。编辑:David.Liu于2015年11月20日上午2:15
以上来自于谷歌翻译
     以下为原文
  Hi,
The SIMULATED mode in Command Expert will not give you any result, this mode is just for leaving the connect as blank when editing sequence, after your sequence is done, you have to find the actual address of your instrument and modify the connection step. However you can use some software applications to simulate an instrument and connect Command Expert to this fake instrument, then you can get some data response.
Edited by: David.Liu on Nov 20, 2015 2:15 AM
举报
更多回帖
