引用: derek88 发表于 2018-10-15 11:31
嗨尼克,我会尝试回答你的问题...让你的程序打开一个空白的excel文件,用数据填充它,然后使用Save Workbook As将它保存在一个新的文件名下,而不是使用文件名选择。
要更改now()的输出,请将其提供给To String对象,并将Defaut格式更改为时间戳格式。
祝你好运,比尔
谢谢回复!
我实际上已经解决了很多我遇到的问题,但我只是登录去询问其他人。
我会稍后开始另一个线程。
“不要使用文件名选择,让程序打开一个空白的excel文件,用数据填充它,然后使用Save Workbook As将其保存在新文件名下。”
我实际上需要将它保存在一个excel文件中。
每次测试运行时我需要的是一张新表。
我得到了这个“想通了”我现在唯一的问题就是新的表单被命名为“63564124664.266”,然后我必须通过转换才能在“3/28/2015 9:52:00 PM”中找到它
“格式。
“要更改now()的输出,请将其输入To To String对象,并将Defaut Format更改为时间戳格式。”
好的,我删除了从“now()”到“New Sheet”框的路径并添加了“To String”(I / O - > To - > String),双击添加一个事务,然后切换“
默认格式“到”时间戳格式“但是当我运行程序时,它返回”错误号553“我附加了一个字母数字显示,它正确显示日期,它只是没有进入”新页面“对象。
谢谢尼克
以上来自于谷歌翻译
以下为原文
Thanks for the reply! I've actually worked through alot of the issues I was having but I was just logging on to ask some others. Ill start another thread for that later though.
"Instead of using File Name Selection, have your program open a blank excel file, fill it with data, then use the Save Workbook As to save it under a new file name."
I actually NEED to keep it saved in a single excel file. What I need is a new sheet every time the testing is run. Ive got this "figured out" my only problem now is the new sheets get named something like "63564124664.266" which I then have to run through a conversion in order to get it in a "3/28/2015 9:52:00 PM" format.
"To change the output of now() feed it to a To String object and change Defaut Format to Time Stamp Format."
Ok so I deleted the path from the "now()" to the "New Sheet" box and added in a "To String" (I/O -> To -> String), double clicked to add a transaction, then switched "DEFAULT FORMAT" to "TIME STAMP FORMAT" but when I run the program it comes back with "Error Number 553"
I attached an alphanumeric display and it shows the date correctly, its just not going into the "NEW SHEET" object.
Thanks
Nick
祝你好运,比尔
谢谢回复!
我会稍后开始另一个线程。
每次测试运行时我需要的是一张新表。
“格式。
谢谢尼克
以上来自于谷歌翻译
以下为原文
Thanks
Nick
举报
