引用: 60user65 发表于 2018-10-15 16:13
您使用的部分是增强的安全模型,默认情况下启用写保护。
S25FL-S—KBA223 257后缀“Z0”和“Z1”的意义
为了禁用保护,需要一个特定的命令序列,并且Xilinx影响不支持该命令序列。请用S25FL128SABBHI300代替普通模型。
你好,
我试图编程S25FL128LAGMF010,也使用冲击和斯巴达-6。我不认为我的Flash是一个高安全性的模型,但我也遇到了同样的问题。错误:影响:2525–1:设备超出分配时间。
我已经改变了我的环境变量,跳过ID检查。我甚至把我的影响版本降到13.4,如AR 52747:冲击142/3/4-斯巴达-3E-“设备超过了分配的时间”当运行间接程序时失败……(我知道这不是Cypess或SpTAN-6,但是我还是试了一下)。
这是一个新的设计,所以我一直在比较不同的闪存IC。与WiBand项目几乎完全相同,但如果可能的话,我宁愿坚持柏树。有人能提供其他提示吗?
谢谢您!
罗伯特
以上来自于百度翻译
以下为原文
Hello,
I am trying to program the S25FL128LAGMFI010, also using iMPACT and a Spartan-6. I don't think my Flash is a high-security model, but I am getting the same problem. "ERROR:iMPACT:2525 - '1': Device has exceeded the allocated time."
I have changed my Environment Variable to skip the ID check. I even down-graded my version of iMPACT to 13.4, as per
AR# 52747: iMPACT 14.2/3/4 - Spartan-3E - "Device has exceeded the allocated time" failure when running indirect program… (I know this is not for Cypess or Spartan-6, but I gave it a try anyway).
This is for a new design, so I have been comparing different flash ICs. The almost-identical counterparts from Winbond program well, but I would rather stick with Cypress if possible. Can anyone provide any other hints?
Thank you!
Robert
你好,
谢谢您!
罗伯特
以上来自于百度翻译
以下为原文
Hello,
Thank you!
Robert
举报
