亲爱的SPC5Studio团队,
我按照安装程序(备份许可证和工作区,卸载v3.7.1,删除工作区...),我现在有2个问题:
- 我将我的v3.7项目导出为zip文件并在v4.0中导入。我添加了Platform,init和LL驱动程序SLA包,并生成了组件。哪里可以找到驱动程序设置?时钟组件显示时钟设置,确定,但FlexCAN,DSPI设置在哪里?即使我使用向导创建应用程序,我也被卡住了。时钟设置不使用我在configua
tion.xml中使用的值。 v4.0中是否仍支持v3.7 configuration.xml?
- 我将http和https代理设置设置为手动,具有正确的服务器地址,端口,登录和密码,清除袜子条目,并且在启动时日志显示''系统属性https.proxyPort未设置但应该是8080.''和等所有6个属性。申请后只有一次有效,但在寻找更新或市场时,我有两个可能的问题:
- 10次中的9次,日志显示''Provisioning exception''包含''需要HTTP代理身份验证:http://hightec.spc5studio.com/content.xml
要么
- 10次中的1次,取出开始但转移极慢(2kB / s ......)并在20分钟后停止。 ST网站的回复也很慢。 ST端是否有任何问题,或者这可能来自我的代理配置?你会建议什么?
以上来自于谷歌翻译
以下为原文
Dear SPC5Studio Team,
I followed the installation procedure (backup licence and workspace, uninstall v3.7.1, remove workspace...) and I now have 2 problems:
- I exported my v3.7 project in zip file and imported it in v4.0. I added the Platform, init and LL drivers SLA packages and I generate the components. WHERE COULD DRIVERS SETTINGS BE FOUND? The clock component shows clock settings, ok, but where are FlexCAN, DSPI settings??? Even if I create an app using the wizard, i'm stuck. The clock settings are not using the values I used in my configuation.xml. Is the v3.7 configuration.xml still supported in v4.0?
- I set the http and https proxy settings to manual with correct server address, port, login and pwd, clear socks entries, and at startup the log says ''System property https.proxyPort is not set but should be 8080.'' and so on for all 6 properties. Only one time it worked after applying but when looking for updates or market place I had 2 possible issues:
- 9 times out of 10, the log shows ''Provisioning exception'' containing ''HTTP Proxy Authentication Required:
OR
- 1 time out of 10, the fetching starts but the transfer is extremely slow (2kB/s...) and stops after 20 minutes. The ST website is also very slow to respond. Is there any issues on the ST side or could this come from my proxy config? What would you recommand?
