AMM中“单次拍摄模式”功能的目的是获取指定采样点的数据并处理一次。
如果您需要以5秒的固定间隔提供样本数据,我建议您使用带触发功能的连续模式而不是单次模式。
有关您的信息,很少有编程示例,包括IVI驱动程序中提供的单次拍摄模式。
您可以通过以下链接下载U2331A IVI驱动程序。
http://www.keysight.com/main/software.jspx?ckey=1540216&lc=eng&cc=US&nid=-33239.384455&id=1540216您可以使用该示例并相应地进行修改以满足您的需求。
以上来自于谷歌翻译
以下为原文
The purpose of the “Single shot mode” feature in AMM is to acquire the data at specified sample points and processed once. If you need a sample data at regular intervals of say 5 sec , I would like to suggest you to use the continuous mode with trigger function rather than the single shot mode. For your information, there are few programming examples including the single shot mode which available in the IVI drivers. You may download U2331A IVI drivers in the following link as below.
You may use the example and modify accordingly to meet your need.
以上来自于谷歌翻译
以下为原文
举报
