Microchip
直播中
蔡婷
8年用户 224经验值
私信 关注
[问答]
请问引脚是否具有RPI可重映射引脚?
嗨,所有,是引脚与RPI Realppabl引脚,如果是,他们只能定义为输入或输出,以及?我已经在Mikro C PrUnLoCy-IOLOCK()中完成了这一工作;PSPSMAPPIGN NoLoCK(108,输出,αSCK1OUT);//SPI1时钟输入,40 RP108ppsl MAPAPIGN nOLOCK(109,α输出,αSDO1);//SPI1数据输出,39 RP109ppsMappnIn nOLoCK(42,α输出,αSS1OUT);//SPI1 SLAVESEED输出α34 RPI42PPSSMAP NoLoCK(41,μin PU)T,γSDI1);//SPI1数据输入,33 RPI41LoCKIOIOCK();谢谢
以上来自于百度翻译
      以下为原文
    Hi all,
Are the pins with RPI remappable pins and if so, can they only be defined as inputs or output as well?
I have done this in Mikro C Pro
Unlock_IOLOCK();
PPS_Mapping_NoLock (108, _OUTPUT, _SCK1OUT); // SPI1 Clock Input     #40   RP108
PPS_Mapping_NoLock (109, _OUTPUT, _SDO1);   // SPI1 Data Output      #39   RP109
PPS_Mapping_NoLock (42, _OUTPUT, _SS1OUT); // SPI1 SlaveSelect output#34   RPI42
PPS_Mapping_NoLock (41, _INPUT, _SDI1); // SPI1 Data Input           #33   RPI41
Lock_IOLOCK();
Thanks
回帖(1)
吴键洪
2018-10-11 09:00:51
如果一个PIN被标记为“rPix*”而不是“rp*”,那么它只被输入。关于Mikro C如何处理映射的问题最好在Mikro C Boo.HtPSP//FuMU.MikRO.COM/上被问到。
以上来自于百度翻译
      以下为原文
    If a pin is marked "RPI#" rather than "RP#", then it is input only.
Questions about how Mikro C handles mapping would best be asked on the Mikro C board.
https://forum.mikroe.com/
举报
更多回帖
