工程资源中心
直播中
王洋
8年用户 194经验值
私信 关注
[传感器]
具有电感式传感的低功耗水流测量包括BOM及层图
            This reference design demonstrates a highly-integrated solution for this application using an inductive sensing technique enabled by the CC1350 SimpleLink™ Wireless MCU and FemtoFET™ MOSFET. This reference design also provides the platform for integration of wireless communications such  (...)
主要特色
  • Meets measurement accuracy requirements of ISO4064-1:2014-11 (Class 1)
  • Accurate measurement at a distance of 4.2 mm to a wheel (11mm diameter)
  • Accurate flow measurement as low as 11.25 liters per hour
  • Consumes only 4µA with 12Hz sampling rate
  • Support ISM bands in 431 to 527MHz and 861 to 1054MHz range  (...)
更多回帖
