我真的需要修改基板的尺寸,但不能这样做。
我在互联网上找到了三维设计基板的文章。
例如:“基板尺寸:26x45x1 mm”。
但是,当我单击EM Simula
tion Setup,然后在基板中,我创建了一个新的基板。
例如,默认为Alumina,然后单击图层,然后我只有“厚度”选项。
如何设置三维基板?
以上来自于谷歌翻译
以下为原文
I really need to modify the dimensions of the substrate, but can not do it. I find articles on the Internet to design substrates with three dimensions. For example: "Substrate Dimensions: 26x45x1 mm". But when I click EM Simulation Setup, and then in substrate, I create a new substrate. For example, the default is Alumina, then click on the layer, and then I have just the "Thickness" option. How can I set a substrate in three dimensions as well?
