ADI 技术
直播中
李朝
8年用户 210经验值
私信 关注
[问答]
请问AD7150+MSP430G2553如何编码?
想做一个简单的 微电容位移传感器  采用AD7150 来获得电容值
AD7150 是I2C传送数据,因为想做的简单,就用MSP430G2553单片机做主控,模拟I2C通信方式,来获取输入
程式语言部分该如何编码?
底下是我参考open source
msp430g2xx3_uscib0_i2c_12.c
进行修改
但不了解各个状态要如何设定 (寄存器位址等)?
请各位大大协助
#include
#include "msp430g2553.h"
#define NUM_BYTES_TX 1                         // How many bytes?
#define NUM_BYTES_RX 1
int RXByteCtr, RPT_Flag = 0;                // enables repeated start when 1
volatile unsigned char RxBuffer[128];       // Allocate 128 byte of RAM
unsigned char *PTxData;                     // Pointer to TX data
unsigned char *PRxData;                     // Pointer to RX data
unsigned char TXByteCtr, RX = 0;
unsigned char MSData = 0x55;
unsigned int RxWord;
unsigned int RxByteCtr;
unsigned char i;
float        pFdata;
float        chRange;
void Setup_TX(void);
void Setup_RX(void);
void Transmit(void);
void Receive(void);
float AD7150_Cap(void);
void main(void)
WDTCTL = WDTPW + WDTHOLD;                 // Stop WDT
  P1SEL |= BIT6 + BIT7;                     // Assign I2C pins to USCI_B0
  P1SEL2|= BIT6 + BIT7;                     // Assign I2C pins to USCI_B0
  while(1){
  //Transmit process
  Setup_TX();
  RPT_Flag = 1;
  Transmit();
  while (UCB0CTL1 & UCTXSTP);             // Ensure stop condition got sent
  //Receive process
  Setup_RX();
  Receive();
// The USCI_B0 data ISR is used to move received data from the I2C slave
// to the MSP430 memory. It is structured such that it can be used to receive
// any 2+ number of bytes by pre-loading RXByteCtr with the byte count.
#pragma vector = USCIAB0TX_VECTOR
__interrupt void USCIAB0TX_ISR(void)
  if(RX == 1){                              // Master Recieve?
  RXByteCtr--;                              // Decrement RX byte counter
  if (RXByteCtr)
    *PRxData++ = UCB0RXBUF;                 // Move RX data to address PRxData
  else
    if(RPT_Flag == 0)
        UCB0CTL1 |= UCTXSTP;                // No Repeated Start: stop condition
      if(RPT_Flag == 1){                    // if Repeated Start: do nothing
        RPT_Flag = 0;
    *PRxData = UCB0RXBUF;                   // Move final RX data to PRxData
    __bic_SR_register_on_exit(CPUOFF);      // Exit LPM0
  else{                                     // Master Transmit
      if (TXByteCtr)                        // Check TX byte counter
    UCB0TXBUF = MSData++;                   // Load TX buffer
    TXByteCtr--;                            // Decrement TX byte counter
  else
    if(RPT_Flag == 1){
    RPT_Flag = 0;
    PTxData = &MSData;                      // TX array start address
    TXByteCtr = NUM_BYTES_TX;                  // Load TX byte counter
    else{
    UCB0CTL1 |= UCTXSTP;                    // I2C stop condition
    IFG2 &= ~UCB0TXIFG;                     // Clear USCI_B0 TX int flag
void Setup_TX(void){
  _DINT();
  RX = 0;
  IE2 &= ~UCB0RXIE;
  while (UCB0CTL1 & UCTXSTP);               // Ensure stop condition got sent// Disable RX interrupt
  UCB0CTL1 |= UCSWRST;                      // Enable SW reset
  UCB0CTL0 = UCMST + UCMODE_3 + UCSYNC;     // I2C Master, synchronous mode
  UCB0CTL1 = UCSSEL_2 + UCSWRST;            // Use SMCLK, keep SW reset
  UCB0BR0 = 12;                             // fSCL = SMCLK/12 = ~100kHz
  UCB0BR1 = 0;
  UCB0I2CSA = 0x48;                         // Slave Address is 048h
  UCB0CTL1 &= ~UCSWRST;                     // Clear SW reset, resume operation
  IE2 |= UCB0TXIE;                          // Enable TX interrupt
void Setup_RX(void){
  _DINT();
  RX = 1;
  IE2 &= ~UCB0TXIE;
  UCB0BR1 = 0;
  IE2 |= UCB0RXIE;                          // Enable RX interrupt
void Transmit(void){
    UCB0CTL1 |= UCTR + UCTXSTT;             // I2C TX, start condition
    __bis_SR_register(CPUOFF + GIE);        // Enter LPM0 w/ interrupts
void Receive(void){
    PRxData = (unsigned char *)RxBuffer;    // Start of RX buffer
    RXByteCtr = NUM_BYTES_RX-1;              // Load RX byte counter
    UCB0CTL1 |= UCTXSTT;                    // I2C start condition
if(RxByteCtr < 0x3000)
RxByteCtr = 0x3000;
else if ( RxByteCtr >0XD000)
RxByteCtr = 0XD000;
pFdata =(((RxByteCtr)-0x3000)*1)/0x9FF0;
return pFdata;
最後是根據data sheet 所提供公式進行修改
回帖(3)
卢兰凤
2018-10-9 16:43:03
非常抱歉,我们很难帮您验证代码。您是否可以将SCL和SDA这两个管脚的波形用示波器采集下来,上传。可以直观的看到这两个管脚的时序是否是正确的。
举报
李朝
2018-10-9 16:59:45
您好,是否與下圖的時序圖一致,才能達到通訊?
举报
卢兰凤
2018-10-9 17:16:18
必须严格按照手册里要求的时序来读写寄存器。
举报
更多回帖
