TI论坛
直播中
高博
8年用户 179经验值
私信 关注
[问答]
CCSv5.4無法連結目標
我購買了 TMDSHVMTRPFCKIT 及F28035控制卡
並使用隨附的光碟安裝CCSV5.4及controlSUITE
全部安裝好後
我可以使用controlSUITE裡的"HVMTRPFCKIT-PM-ACI-GUI"來啟動馬達
但我使用CCSV5.4時選擇xds100 USB Emulator
並嘗試"test connection"卻發生下面的錯誤訊息
[Start]
Execute the command:
%ccs_base%/common/uscif/dbgjtag -f %boarddatafile% -rv -o -F inform,logfile=yes -S pathlength -S integrity
[Result]
-----[Print the board config pathname(s)]------------------------------------
C:UserspcllabAppDataLocal.TI693494126
    0BrdDattestBoard.dat
-----[Print the reset-command software log-file]-----------------------------
This utility has selected a 100- or 510-class product.
This utility will load the adapter 'jioserdesu***.dll'.
The library build date was 'Apr  1 2013'.
The library build time was '23:55:08'.
The library package version is '5.1.73.0'.
The library component version is '35.34.40.0'.
The controller does not use a programmable FPGA.
The controller has a version number of '4' (0x00000004).
The controller has an insertion length of '0' (0x00000000).
This utility will attempt to reset the controller.
This utility has successfully reset the controller.
-----[Print the reset-command hardware log-file]-----------------------------
The scan-path will be reset by toggling the JTAG TRST signal.
The controller is the FTDI FT2232 with USB interface.
The link from controller to target is direct (without cable).
The software is configured for FTDI FT2232 features.
The controller cannot monitor the value on the EMU[0] pin.
The controller cannot monitor the value on the EMU[1] pin.
The controller cannot control the timing on output pins.
The controller cannot control the timing on input pins.
The scan-path link-delay has been set to exactly '0' (0x0000).
-----[The log-file for the JTAG TCLK output generated from the PLL]----------
There is no hardware for programming the JTAG TCLK frequency.
-----[Measure the source and frequency of the final JTAG TCLKR input]--------
There is no hardware for measuring the JTAG TCLK frequency.
-----[Perform the standard path-length test on the JTAG IR and DR]-----------
This path-length test uses blocks of 512 32-bit words.
The test for the JTAG IR instruction path-length failed.
The JTAG IR instruction scan-path is stuck-at-ones.
The test for the JTAG DR bypass path-length failed.
The JTAG DR bypass scan-path is stuck-at-ones.
-----[Perform the Integrity scan-test on the JTAG IR]------------------------
This test will use blocks of 512 32-bit words.
This test will be applied just once.
Do a test using 0xFFFFFFFF.
Scan tests: 1, skipped: 0, failed: 0
Do a test using 0x00000000.
Test 2 Word 0: scanned out 0x00000000 and scanned in 0xFFFFFFFF.
Test 2 Word 1: scanned out 0x00000000 and scanned in 0xFFFFFFFF.
Test 2 Word 2: scanned out 0x00000000 and scanned in 0xFFFFFFFF.
Test 2 Word 3: scanned out 0x00000000 and scanned in 0xFFFFFFFF.
Test 2 Word 4: scanned out 0x00000000 and scanned in 0xFFFFFFFF.
Test 2 Word 5: scanned out 0x00000000 and scanned in 0xFFFFFFFF.
Test 2 Word 6: scanned out 0x00000000 and scanned in 0xFFFFFFFF.
Test 2 Word 7: scanned out 0x00000000 and scanned in 0xFFFFFFFF.
The details of the first 8 errors have been provided.
The utility will now report only the count of failed tests.
Scan tests: 2, skipped: 0, failed: 1
Do a test using 0xFE03E0E2.
Scan tests: 3, skipped: 0, failed: 2
Do a test using 0x01FC1F1D.
Scan tests: 4, skipped: 0, failed: 3
Do a test using 0x5533CCAA.
Scan tests: 5, skipped: 0, failed: 4
Do a test using 0xAACC3355.
Scan tests: 6, skipped: 0, failed: 5
Some of the values were corrupted - 83.3 percent.
The JTAG IR Integrity scan-test has failed.
-----[Perform the Integrity scan-test on the JTAG DR]------------------------
The JTAG DR Integrity scan-test has failed.
[End]
根據其手冊我確定硬體上接口沒有問題
F28035控制卡上的開關位置也確定是
SW1=off,SW3=off,SW2=on.
請問有人遇過相同狀況或是知道怎麼解決嗎
謝謝
回帖(8)
张嘉
2018-10-8 17:18:41
请对照High Voltage Motor Control and PFC (R1.1) Kit Hardware Reference Guide检查,可以参看章节3.3 Boot Modes和3.4 GUI Connection,除了拨码开关SW1,2,3之外,跳针[Main]-J9和[M3]-JP1也请确认一下.
举报
高博
2018-10-8 17:33:47
此兩部分也已確認如附圖
此部分也想確認一下
跳針populated 跟 unpopulated
指的是跳針頭無外露與 有外露嗎?
举报
张嘉
2018-10-8 17:41:31
引用: Bowen_ 发表于 2018-10-4 14:46
此兩部分也已確認如附圖
此部分也想確認一下
populated 表示连接,unpopulated表示不连接,再根据两个引脚的定义看连接是使能还是禁止
举报
高博
2018-10-8 17:47:33
想請問一個問題
我參考了"High Voltage Motor Control and PFC (R1.1) Kit Hardware Reference Guide"的3-4節 GUI connection
它表示 remove the jumper [Main]-J9
但另外一篇文件"HVMotorCtrl+PFC(R1.1)Kit How to Run Guide"中 motor Control Experiment HW Setup Instructions 的第2點
它寫 Install the Jumpers[Main]-J9 JTAG reset line
如果我想要使用CCSv5.4連接 TMDSHVMTRPFCKIT板子
我該參考哪一篇文件??
举报
更多回帖
