这取决于远程处理协议将鼠标位置从客户端传输到VM然后报告它的方式。
根据游戏引擎如何识别鼠标位置将影响鼠标是否在游戏本身中有效表现。
由于GRID Test-Drive不适用于游戏,因此它为企业应用程序设置,通常以不同方式处理鼠标位置数据。
如果您正在寻求开发游戏平台,那么我建议您查看GRID SDK,它将允许您为SHIELD创建一个类似GRID Game Streaming服务的解决方案。
https://developer.nvidia.com/grid-app-game-streaming
以上来自于谷歌翻译
以下为原文
This is down to the way in which the remoting protocols transmit the mouse position from the client to the VM and then report it.
Depending on how the game engine recognises the mouse position will have an effect on whether the mouse is effectively represented in the game itself.
Since GRID Test-Drive is not intended for use with gaming it's set up for Enterprise applications, which typically treat mouse position data differently.
If you're looking to develop a gaming platform, then I'd suggest looking at the GRID SDK which would allow you to create a solution like the GRID Game Streaming service for SHIELD.
以上来自于谷歌翻译
以下为原文
举报
