NVIDIA技术支持为我提供了获得许可证的解决方案。
它不优雅,但它有效。
基本上是您重建许可证服务器。
在重建许可证服务器后,我关闭了所有虚拟机并重新启动。
你好Gary,
你是对的,许可证租约将在默认7天后超时。
您可以通过以下步骤清除可信存储:
清除可信存储
1.登录NVIDIA许可门户:https://nvid.nvidia.com/dashboard/#/dashboard
2.单击“搜索许可证服务器”并选择相应的注册服务器
3.单击NVIDIA Licensing Portal中的Remove Add-Ons
4.在要删除的数量中输入当前在设备上的数量,然后单击删除附加组件
5.关闭许可证服务器上运行的所有浏览器
6.进入Microsoft控制面板,管理工具和服务
7.找到“FlexNet许可证服务器 - nvidia”服务,右键单击它并选择停止
8.从以下位置删除nvidia文件夹:
C: WINDOWS ServiceProfiles 网络服务 flexnetls
9.进入Microsoft控制面板,管理工具和服务
10.找到“FlexNet许可证服务器 - nvidia”服务。
右键单击它并选择开始
11.如果适用,在NVIDIA软件许可证门户中注册MAC地址
12.单击“搜索许可证服务器”并选择已注册的服务器
13.单击“下载许可证文件”,将其保存到本地驱动器,然后将其丢弃(参见注释)
14.单击NVIDIA许可门户中的Map Add-Ons
15.在“要添加的数量”框中输入要映射的附加组件数,然后单击“地图附加组件”
16.单击“下载许可文件”
17.将许可证bin文件保存到磁盘,并在24小时内上传到本地许可证服务器
注意:需要步骤13从NVIDIA许可证门户清除服务器信息
亲切的问候,
亚历山大
NVIDIA企业支持团队
以上来自于谷歌翻译
以下为原文
The NVIDIA tech support gave me a solution to getting my licenses back. It's not elegant, but it worked. Essentially your rebuilding you license server. I had all my vm's shutdown and restarted after I had rebuilt the license server.
Hello Gary,
You're correct, the license lease will time out after default 7 days.
You may clear Trusted Storage with following steps:
To Clear Trusted Storage
1. Log into NVIDIA Licensing Portal: https://nvid.nvidia.com/dashboard/#/dashboard
2. Click on Search License Servers and select the appropriate registered server
3. Click on Remove Add-Ons in the NVIDIA Licensing Portal
4. Enter number of Currently on Device in Quantity to Remove and click Remove Add-Ons
5. Close all browsers that are running on the license server
6. Go into the Microsoft Control Panel, Administrative Tools and Services
7. Locate the “FlexNet License Server – nvidia” service, right click on it and select Stop
8. Delete the nvidia folder from:
C:WindowsServiceProfilesNetworkServiceflexnetls
9. Go into the Microsoft Control Panel, Administrative Tools and Services
10. Locate the “FlexNet License Server – nvidia” service. right click on it and select Start
11. Register the MAC address in the NVIDIA Software License Portal if applicable
12. Click on Search License Servers and select the registered server
13. Click on Download License File, save it to a local drive, then discard it (see note)
14. Click on Map Add-Ons from the NVIDIA Licensing Portal
15. Enter number of Add-Ons you want mapped in Qty to Add box and click on Map Add-Ons
16. Click Download License File
17. Save license bin file to disk and upload to local license server within 24 hours
Note: Step 13 is required to clear server information from the NVIDIA License Portal
Kind regards,
Aleksandar
NVIDIA Enterprise Support Team
它不优雅,但它有效。
基本上是您重建许可证服务器。
你好Gary,
您可以通过以下步骤清除可信存储:
清除可信存储
5.关闭许可证服务器上运行的所有浏览器
8.从以下位置删除nvidia文件夹:
右键单击它并选择开始
16.单击“下载许可文件”
亲切的问候,
亚历山大
NVIDIA企业支持团队
以上来自于谷歌翻译
以下为原文
Hello Gary,
Kind regards,
Aleksandar
举报
