嗨Vee用户,我有一个Vee测试,我从.csv文件中读取了许多参数,执行测试循环,并在每个循环结束时将结果存储在another.csv文件中。
除了测量结果,我保存了一些导入的参数,其中一个是文本条目数组。
所有其他值都转到结果文件,但这些文本条目导致问题。
我在公式框中创建.csv行条目,如下所示:InputPin1 +“,”+ InputPin2 +“,”+ ...等。
其中一些输入引脚的值是从具有另一个公式框的数组中获得的,如下所示:Array [index]。
只要写入.csv文件的项目来自测量循环或从第一个.csv文件创建的数字(非文本)数组,这一切都可以正常工作。
我在我的csv文件中打开结果(在Excel中打开),如下所示:NumberFromArray MeasurementResult CounterNumber NumberFromArray NumberFromArray MeasurementResult CounterNumber NumberFromArray NumberFromArray MeasurementResult CounterNumber NumberFromArray etc ...但是当我从文本数组中读取时,我写的.csv文件有错误开始
在第二行上,如下所示:NumberFromArray MeasurementResult CounterNumber TextFromArray NumberFromArray MeasurementResult CounterNumber TextFromArray NumberFromArray MeasurementResult CounterNumber TextFromArray NumberFromArray MeasurementResult CounterNumber TextFromArray .......就像一个行尾以某种方式找到它的方式。
如果我用文本常量,数字或NumberArray [index]替换TextArray [index]输入,一切正常。
我已经尝试了我在测量例程中所能想到的一切以及导入.csv并创建数组的UserFunc
tion,但我无法让它工作。
我也无法理解为什么问题从第二行开始。
对此有任何建议将不胜感激。
谢谢,唐
以上来自于谷歌翻译
以下为原文
Hi Vee users,
I have a Vee test where I read a number of parameters from a .csv file, perform a test loop, and store the results in another.csv file at the end of each loop.
Along with the measurement results, I save some of the imported parameters, one of which is an array of text entries. All other values go to the results file fine but these text entries are causing a problem.
I am creating the .csv line entry in a formula box like this: InputPin1+","+InputPin2+","+...etc. The values on some of these input pins are obtained from arrays with another formula box like this: Array[index].
This all works well as long as the items written to the .csv file come from the measurement loop or number (not text) arrays created from the first .csv file. I get results in my csv file (opened in Excel) like this:
etc...
But as soon as I read from the text array the .csv file I write has errors beginning on the second line like this:
TextFromArray
TextFromArray
TextFromArray
It's as if an end of line is finding it's way in somehow. If I replace the TextArray[index] input with a text constant, a number, or a NumberArray[index] everything works fine. I have tried everything I can think of in my measurement routine and the UserFunction that imports the .csv and creates the arrays, but I just can't get it working. I also can't understand why the problem begins on the second line.
Any suggestions on this would be greatly appreciated.
Thanks,
Don
