Microchip
直播中
宋阳
8年用户 144经验值
私信 关注
[问答]
PIC18F67J60(旧TCP/IP协议栈)与硬件SSL / TLS?
嗨,有可能在“OLTD”TCP/IP STACK硬件SSL/TLS中实现。对于软件解决方案,没有更多的资源。谢谢帮助。安迪
以上来自于百度翻译
      以下为原文
    Hi,
It is possible to implementing in 'old' TCP/IP Stack hardware SSL/TLS.
For software solution there are no resources more.
Thanks for Help.
Andy
回帖(3)
陈晨
2018-10-8 16:05:44
作为猜测,您需要大量的代码空间和时间来进行加密和解密。我不认为PIC18有它。
以上来自于百度翻译
      以下为原文
    As a Guess No.  You would need alot of code space and time to do the encryption and decryption.  I do not think the PIC18 has it.
举报
王淑英
2018-10-8 16:21:50
如果使用WiC1500 WiFi模块,则内置TLS。TCP/IP协议栈也是如此,所以不需要使用MLA堆栈代码。您确实需要对芯片进行SPI驱动,并在Atmel库代码上运行端口。
以上来自于百度翻译
      以下为原文
    If you use the WINC1500 WiFi module TLS is built in.  So is the TCP/IP stack, so you do not need to use the MLA stack code.  You do need to impement the SPI driver for the chip, and port over the Atmel library code.
举报
杨兰兰
2018-10-8 16:33:45
谢谢你的回答。我有PIC18F67 J60的应用程序(多年来不能改变它),并且没有更多的资源(工作,但太大)来自MLA 5.xx的SSL解决方案。我想做加密/解密。是否有人通过SPI、AT2C、PIC18或任何其他解决方案来体验ATMEL加密设备?谢谢
以上来自于百度翻译
      以下为原文
    Thanks for answers.
I have application with PIC18F67J60 (since years and can not change it) and have no more resources for (working but far too large) SSL solution from MLA 5.xx. I want to make encryption/decryption outside.
Do have anybody experience with e.g. Atmel Encryption devices via SPI, I2C with PIC18 or any another solution?
Thanks
举报
更多回帖
