你需要把一个接近传感器连接到CasSoC上。您可以插入一个定制的接近布局/电路设计,以获得更多的范围/灵敏度,通过以下附注,SZIN链接。第9页开始详细介绍邻近电路布局/指南。该文档还详细描述了如何/如何/为什么使用接近感测。
回答你的直接问题:是的,你需要一个单独的PCB /接近电路连接到电极。
您可以仅用理论设计电路,但有足够的随机变量,您将想要测试设计并调整物理设置,以最大限度地提高设计约束。
以上来自于百度翻译
以下为原文
You need to wire up a proximity sensor to the capsense. You can plug in a custom proximity layout/circuit design to get more range/sensitivity by following the appnote that
szin linked. Page 9 has the start of the section detailing proximity circuit layout/guidelines. The document also describes what/how/why to use proximity sensing in detail.
In answer to your direct questions: Yes, you will need a separate PCB/proximity circuit connected to the electrodes.
You can design the circuit with theory only, but there are enough random variables that you will want to test your design and tweak physical setup to maximize your design constraints.
以上来自于百度翻译
以下为原文
举报
