The tiDA-00455 camera hub reference design allows up to four 1.3 Megapixel cameras to be connected to a TDA2x SoC Evaluation Module (EVM). Each camera connects to the hub through a single coax cable. There are two OmniVision OV490 ISPs on the board that process the video and export it in (...)
主要特色
Accepts four camera inputs over FPD-Link III
Utilizes two OmniVision OV490 ISP's to create DVP output to TDA2x
Provides wide range supply voltage for power over coax (4-14V)
Connects directly to the parallel video ports on a TDA2x EVM
Optimized to work with OminiVision OV10640 imagers
