英伟达
直播中
高颖
8年用户 180经验值
私信 关注
[问答]
从哪里开始使用Nvidia K1-XenDesktop和UCS 240
我刚刚用Vsphere 5.5设置了UCS 240。
准备好使用Win 7设置XenDesktop和专用VMS。
如何获取Nvidia驱动程序设置以及桌面上的测试?
是否有安装用户手册或某种类型的文档?
谢谢
戴夫
以上来自于谷歌翻译
以下为原文
I have just setup a UCS 240 with Vsphere 5.5.  Getting ready to setup XenDesktop and dedicated VMS using Win 7.
How do I get the Nvidia drivers setup and on the desktops for testing?
Is there a installuser manual or doc of some type?
Thanks
Dave
回帖(1)
王丽
2018-9-29 14:33:58
嗨DaveKoz,
不确定我是否理解您的问题但是如果您希望在GPU-Passthrough模式下在vSphere 5.5上运行使用XenDesktop的Windows 7 VM,我建议您查看下面的VMware白皮书。
它包含有关如何安装GPU-Passthrough(vDGA)的详细部分。
您需要按照安装步骤操作,直到安装Citrix VDA。
https://www.vmware.com/files/pdf/techpaper/vmware-horizo​​n-view-graphics-acceleration-deployment.pdf
谢谢,
埃里克
Erik Bohnhorst |
解决方案架构师 -  GRID
NVIDIA公司
以上来自于谷歌翻译
以下为原文
Hi DaveKoz,
not sure that I understand your question but if you want to get a Windows 7 VM running with XenDesktop on vSphere 5.5 in a GPU-Passthrough mode, I encourage you to have a look at the below VMware Whitepaper. It includes a detailed section on how to install GPU-Passthrough (vDGA). You would need to follow the installation steps till the point where you install the Citrix VDA.
https://www.vmware.com/files/pdf/techpaper/vmware-horizon-view-graphics-acceleration-deployment.pdf
Thanks,
Erik
Erik Bohnhorst | Solution Architect – GRID
NVIDIA Corporation
举报
更多回帖
