PNA-X后面板上有一个设备侧USB连接器(见下图)。
您只需使用标准USB电缆将PC连接到PNA-X即可。
然后,您可以使用NI MAX应用程序将PNA-X配置为USB仪器。
这是NI网站的_ * link * _,以获取有关如何执行此操作的说明。
将PNA-X配置为USB设备并验证可以与PC通信后,只需更改您使用的VISA资源ID字符串即可使用所有通过SCPI控制PNA-X的现有应用程序
连接到PNA-X。
对于USB仪器,资源ID字符串将如下所示:USB0 :: 2391 :: 11288 :: + [pna-x主机名或IP地址] + :: 0 :: INSTR!https://dl.dropboxusercontent.com
/u/87949221/Forum/ThreadID_119530/PNAX-DeviceUSB.png!
以上来自于谷歌翻译
以下为原文
the PNA-X has a device side USB connector on the back panel(see picture below). all you need is to connect your PC to the PNA-X using a standard USB cable. you can then use your NI MAX application to configure the PNA-X as a USB instrument. Here is a
_*link*_ to an NI website for directions on how to do that. Once you have configured the PNA-X as a USB device and verified that you can communicate with it with your PC, you then use all your existing applications that control the PNA-X with SCPI by simply changing the VISA resource ID string that you use to connect to the PNA-X. for a USB instrument the resource ID string will look something like this:
USB0::2391::11288::+[pna-x hostname or ip address]+::0::INSTR
!https://dl.dropboxusercontent.com/u/87949221/Forum/ThreadID_119530/PNAX-DeviceUSB.png!
连接到PNA-X。
以上来自于谷歌翻译
以下为原文
举报
