Cypress技术论坛
直播中
余小娟
8年用户 251经验值
私信 关注
[问答]
Ble Scan RX power db问题
您好!
我的项目是基于下面的链接。
(Loop:PSOC-4-BLU/100A项目,在100-100天/天010A观察者在Master·CyPress半导体公司/PSOC-4-BLE·GITHUB)
主要目的是扫描周围的信标。
然而,我想减少观察者的RX功率,因为远离观察者的信标也被扫描。
我知道在BLYBLLDRYCFG1寄存器中的LNA增益值调整了RX功率。
我可以在BLULIGRESTURSTRTM文件中看到VHG、HG、HY、MH、LG和VLG设置。
(参考链接:PSoC 4100-BL/4200 -BL系列:PSoC®4 BLE注册技术参考手册(TRM))
我这里有一个问题。
你知道上面设定的DBS有多少吗?
我想知道通过以上设置得到的RX的DB值。
桑斯克
以上来自于百度翻译
     以下为原文
  Hi
My project is based on the links below.
  (Link : PSoC-4-BLE/100_Projects_in_100_Days/Day010_Observer at master · cypresssemiconductorco/PSoC-4-BLE · GitHub)
The main purpose is to scan surrounding beacons.
However, I would like to reduce the rx power of the observer, because the beacon, which is far from the observer, is also scanned.
I know that the LNA_GAIN value in the BLE_BLERD_CFG1 register adjusts the rx power.
I can see the VHG, HG, IGH, MH, LG, and VLG settings in the BLE_Register_TRM document.
(reference link : PSoC 4100-BL/4200-BL Family: PSoC® 4 BLE Registers Technical Reference Manual (TRM) )
I have one questions here.
Do you actually know how many dBs the above settings are?
I want to know the db value of rx that I get through the above settings.
Thansk
回帖(4)
黎歆俭
2018-9-29 16:20:22
ATM的TRM不让我从柏树网站下载它,但我稍后再试。在猜测中,它将是在1.5分贝、3分贝或6分贝(3分贝是双)的某个地方。
以上来自于百度翻译
     以下为原文
  Atm the TRM isn't letting me download it from the Cypress site, but I'll try again later. At a guess, it would be somewhere on the order of 1.5 dB, 3 dB, or 6 dB (3 dB is double).
举报
黎歆俭
2018-9-29 16:25:28
在TRM中,页面347指的是101的LNA增益设置为66分贝,并且在该设置级别的增加电流的代价下,将灵敏度提高2-3分贝(听起来像它将在其他级别提升它,几乎没有影响)。
最高的是66分贝,最低是0分贝,我会看到步骤为13.2分贝。
以上来自于百度翻译
     以下为原文
  Looking in the TRM, page 347 refers to the LNA gain setting of 101 being 66 dB, and the potential to boost the sensitivity by 2-3 dB at the expense of increased current at that setting level (sounds like it will boost it at other levels with little-to-no effect.)
With the highest being 66 dB, and the lowest being 0 dB, I would see the steps as 13.2 dB
举报
余小娟
2018-9-29 16:32:53
我在下面的链接中看到了组件文档。
(HTTP://www. CyPress)/DooptTys/CaseDeaSeTeSs/PSoC-CaltoReal-组件数据表-BootoSt-低能量BLE)
在P84中,我看到了函数“CyByth-SrrxgGaNeMyType”。
在函数描述中,“CyByByBelsHyg-GAIN模式”设置被称为-91dB。
减去DB和PLUS DB之间的区别是什么?
LNA增益和CyLySyxGrGAIN模式设置是如何匹配的?
以上来自于百度翻译
     以下为原文
  I saw the component document at the link below.
(http://www.cypress.com/documentation/component-datasheets/psoc-creator-component-datasheet-bluetooth-low-energy-ble )
In p84, I saw the function "CyBle_SetRxGainMode"
In the function description, the "CYBLE_BLESS_HIGH_GAIN_MODE" setting is called -91dB.
What is the difference between minus db and plus db?
And how does the LNA Gain and CyBle_SetRxGainMode settings match?
举报
黎歆俭
2018-9-29 16:48:33
引用: abc1763613206 发表于 2018-9-29 19:36
我在下面的链接中看到了组件文档。
正dB是较强的信号;负dB在信号强度上是相同的比例变化,但它反而减弱了信号强度。
正常VS高增益模式相差2dB差值,这大约是信号接收灵敏度的1.6倍。
无线电列表-作为默认RX灵敏度的89分贝,因为这是来自正确增益的单位增益发射机的信号的分数功率。例如,在到达接收机之前,在1 W/m ^ 3处发射的无线电将在接收机的信号强度下降89分贝时接收,这个DB值对应于需要的信号强度的0.0000000126 W/m ^ 3。(这是一个粗略的计算,但它演示了数学和概念相当好。)
不知道LNA如何与CyByLyStRxGangMeDeNe()函数匹配,但它可以是TRM和CyPress函数之间的区别,它将TRM中找到的设置设置为每个设置/模式的特定配置。
以上来自于百度翻译
     以下为原文
  Positive dB is a stronger signal; Negative dB is the same proportional change in signal strength, but it is decreased signal strength instead.
The Normal vs High Gain modes differ by the 2dB difference, which is a roughly 1.6~ times increase in signal reception sensitivity.
The radio lists -89 dB as the default RX sensitivity as that is the fractional power of a signal from a unity-gain transmitter that can be correctly received. For example, a radio transmitting at 1 W/m^3 would be receivable by the receiver at a -89 dB drop in signal strength before reaching the receiver, this dB value corresponds to 0.0000000126 W/m^3 of signal strength needed to function. (This is a rough calculation, but it demonstrates the math and concept pretty well.)
No idea how the LNA Gain matches to the CyBle_SetRxGainMode() function, but it could be a difference between the TRM and the cypress function that sets the settings found in the TRM to specific configurations for each setting/mode.
举报
更多回帖
