燃气烟雾检测模块MQ-2在上篇博客中已经写好了,接下来是温湿度检测模块dht11了,模块信息在前面已经介绍过了,这里就不再赘述了,直接看程序:
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include time.h>
#include
#include
#define DEVICE_NAME "dht11"
#define DEVICE_MAJOR 0
struct dht11_sensor_dev{
int pin;
unsigned char value[5];
int signal;
int time;
int count;
dev_t devno;
struct class *dht11_class;
struct cdev cdev;
struct mutex read_data;
struct timeval lasttv;
struct timeval tv;
struct work_struct dht11_work;
static struct dht11_sensor_dev *dht11_dev;
static int read_byte(void){
unsigned char data;
int i = 0;
for(i = 0; i < 8; i++){
while(!gpio_get_value(dht11_dev->pin));
udelay(30);
data <<= 1;
if(gpio_get_value(dht11_dev->pin) == 1){
data |=0x01;
while(gpio_get_value(dht11_dev->pin));
}else{
data |=0x00;
return data;
static void dht11_read(void){
int i = 0;
dht11_dev->signal = gpio_get_value(dht11_dev->pin);
if(dht11_dev->signal == 0){
for(i = 0; i < 5; i++){
dht11_dev->value = read_byte();
static int dht11_start(void)
gpio_direction_output(dht11_dev->pin, 0);
msleep(20);
gpio_set_value(dht11_dev->pin,1);
udelay(20);
gpio_direction_input(dht11_dev->pin);
do_gettimeofday(&dht11_dev->lasttv);
dht11_dev->count=0;
return 0;
static int dht11_checksum(struct dht11_sensor_dev *dev)
int tmp = 0;
tmp = dev->value[0] + dev->value[1] + dev->value[2] + dev->value[3];
if((tmp != dev->value[4]) || (dev->value[4] == 0) || (tmp == 0) ){
printk(KERN_INFO "[%s] %d %dn", __func__, dev->value[4], tmp);
return -1;
return 1;
static int dht11_sensor_open(struct inode *inode, struct file *filp)
printk("dht11_sensor_openn");
return 0;
static ssize_t dht11_sensor_read(struct file *filp,char __user *buf,size_t
size,loff_t *f_pos)
int result = 0;
dht11_dev->value[0] = 0;
dht11_dev->value[1] = 0;
dht11_dev->value[2] = 0;
dht11_dev->value[3] = 0;
dht11_dev->value[4] = 0;
printk("dht11_sensor_readn");
dht11_start();
dht11_read();
msleep(10);
result=dht11_checksum(dht11_dev);
if(result<0)
return -EAGAIN;
printk("---Humidity=%d.%d%%RHn---Temperature=%d.%dCn",
dht11_dev->value[0], dht11_dev->value[1],
dht11_dev->value[2], dht11_dev->value[3]);
result=copy_to_user(buf,&dht11_dev->value,4);
if(result<0)
printk("copy to user errn");
return -EAGAIN;
return result;
static int dht11_sensor_release(struct inode *inode,struct file *filp)
module_put(THIS_MODULE);
return 0;
static struct file_operations dht11_sensor_fops={
.owner = THIS_MODULE,
.open = dht11_sensor_open,
.read = dht11_sensor_read,
.release = dht11_sensor_release,
//static int dht11_gpio_init(void)
static int parse_dt (struct platform_device *pdev,struct dht11_sensor_dev *data){
int result;
struct device_node *node = pdev->dev.of_node;
data->pin = of_get_named_gpio(node,"thunder,gpio_data",0);
if(gpio_is_valid(data->pin)){
result=gpio_request(data->pin, "dht11_gpio");
if(result)
printk(KERN_INFO "[%s] gpio_request n", __func__);
return -1;
gpio_direction_output(data->pin,1);
return 0;
static int dht11_sensor_setup_cdev(void)
int ret;
cdev_init(&(dht11_dev->cdev), &dht11_sensor_fops);
dht11_dev->cdev.owner = THIS_MODULE;
ret=cdev_add(&(dht11_dev->cdev),dht11_dev->devno, 1);
if(ret)
printk(KERN_NOTICE"erro %d adding %sn",ret,DEVICE_NAME);
return ret;
static int dht11_probe(struct platform_device *pdev){
int result;
dht11_dev=kmalloc(sizeof(struct dht11_sensor_dev),GFP_KERNEL);
if(!dht11_dev)
result=-ENOMEM;
goto allocate_memory_fail;
if(DEVICE_MAJOR)
result = register_chrdev_region(dht11_dev->devno, 1, DEVICE_NAME);
else
result = alloc_chrdev_region(&dht11_dev->devno, 0, 1, DEVICE_NAME);
if(result < 0)
printk("register_chrdev_region err!n");
goto chardev_region_fail;
dht11_dev->dht11_class = class_create(THIS_MODULE, DEVICE_NAME);
if(IS_ERR(dht11_dev->dht11_class))
printk("Err: failed in creating class.n");
goto class_create_fail;
device_create(dht11_dev->dht11_class, NULL,dht11_dev->devno, NULL,
DEVICE_NAME);
result = parse_dt(pdev,dht11_dev);
if(result<0)
goto gpio_request_fail;
result=dht11_sensor_setup_cdev();
if(result<0)
goto cdev_fail;
mutex_init(&dht11_dev->read_data);
printk("dht11 init ok!n");
return 0;
gpio_request_fail:
cdev_del(&dht11_dev->cdev);
cdev_fail:
device_destroy(dht11_dev->dht11_class,dht11_dev->devno);
class_destroy(dht11_dev->dht11_class);
class_create_fail:
unregister_chrdev_region(dht11_dev->devno,1);
chardev_region_fail:
allocate_memory_fail:
kfree(dht11_dev);
return result;
static int dht11_remove(struct platform_device *pdev)
unregister_chrdev_region(dht11_dev->devno, 1);
kfree(dht11_dev);
return 0;
static struct of_device_id dht11_match_table[] = {
{ .compatible = "thunder,dht11",},
static struct platform_driver dht11_driver = {
.probe = dht11_probe,
.remove = dht11_remove,
.driver = {
.name = DEVICE_NAME,
.of_match_table = dht11_match_table,
module_platform_driver(dht11_driver);
MODULE_AUTHOR("wi");
MODULE_DESCRIPTION("DHT11 Driver");
MODULE_LICENSE("GPL");
这个模块用的是单总线,所以时序要特别注意一下,设备节点:/dev/dht11
为了检测数据的正确性,以及节点是否可用,写了下面一个小程序进行测试:
#include
#include
#include
#include
#include
#include
#include
int main(){
int fd;
int ret;
int i = 0;
unsigned char buf[4];
fd = open("/dev/dht11", O_RDONLY);
if(fd < 0){
printf("open the dht11 id failedn");
return fd;
ret = read(fd, buf, 4);
if(ret < 0){ //下面三个输出可以了解一下,对于打开,读写节点失败的调试很有帮助的。
printf("errno= %dn", errno);
printf("Mesg----%sn",strerror(errno));
perror("read failed");
return ret;
printf("---Humidity=%d.%d%%RHn---Temperature=%d.%dCn", buf[0], buf[1], buf[2], buf[3]);
close(fd);
return 0;
经过测试是没有问题的。到此温湿度检测模块dht11的底层驱动也完成了。
