ST意法半导体
直播中
贾玲
8年用户 184经验值
私信 关注
[问答]
设置LIS2DH以进行6D运动识别需要配置什么
我正在尝试设置LIS2DH来检测运动并驱动INT1。文档不清楚需要配置什么才能执行此操作。
CNTL_REG3似乎选择了INT1的来源。有两个是AOI选项。我假设由于6D移动功能与AOI(表51,中断模式)相关联,因此需要在该寄存器中设置这些位中的至少一个。
在INT1_CFG中,很明显可以为“6方向移动识别”设置位6和7,但是还必须设置其他位吗?
是否有将此模式用于此零件或类似零件的示例?
#lis2dh
以上来自于谷歌翻译
以下为原文
I am trying to setup the LIS2DH to detect movement and drive INT1.  The documentation is not clear what needs to be configured to do this.
CNTL_REG3 appears to select the sources for INT1.  There are two that are AOI options.  I am assuming since the 6D movement function is associated with the AOI (Table 51, Interrupt Mode), that at least one of these bits needs to be set in this register.
In INT1_CFG, it is clear that bits 6 and 7 can be set for ''6 direction movement recognition'', but do the other bits also have to be set?
Is there an example of using this mode for this part or similar parts?
#lis2dh
回帖(1)
张鑫
2018-9-28 17:02:38
你好迈克尔,
 为了设置LIS2DH以进行6D运动识别,您必须配置INT1_CFG(30h)以启用6方向检测功能的检测,并且还必须配置CTRL_REG5(24h)以将其视为INT1或INT2上的中断。
 我附上了一张图片,其中包含我对寄存器设置的建议以及数据表,您可以在表38,49和50中找到有关它的更多详细信息。
 非常感谢你,
 蒂亚戈雷斯
以上来自于谷歌翻译
以下为原文
Hello Michael,
In order to setup LIS2DH for 6D movement recognition, you have to configure INT1_CFG (30h) to enable the detection of the 6 direction detection function, and also on CTRL_REG5 (24h) to consider it as an Interrupt either on INT1 or INT2.
I have attached an image with my recommendation for the registers setup and also the datasheet where you can find in table 38, 49 and 50 more details about it.
Thank you very much,
Thiago Reis
举报
更多回帖
