工程资源中心
直播中
蒋美燕
8年用户 967经验值
私信 关注
高速直接RF采样GSPS ADC的时钟解决方案包括BOM及框图
            The tiDA-01015 is a clocking solution reference design for high speed direct RF sampling GSPS ADCs. This design showcases the significance of the sampling clock to achieve high SNR for 2nd Nyquist zone input signal frequencies. ADC12J4000 is a 12-bit, 4-GSPS RF sampling ADC with 3-dB input bandwidth  (...)
主要特色
  • 12-bit, 4-GSPS RF sampling ADC clocking solution
  • Up to 4-GHz input signal capture capability
  • JESD204B compliant low-phase noise clocking solution for RF sampling ADC
更多回帖
