Qualcomm Linux
diff --git a/android-lte/kernel/drivers/input/keyboard/tca8418_keypad.c b/android-lte/kernel/drivers/input/keyboard/tca8418_keypad.c
index 187ff5b..682109b 100755
--- a/android-lte/kernel/drivers/input/keyboard/tca8418_keypad.c
+++ b/android-lte/kernel/drivers/input/keyboard/tca8418_keypad.c
@@ -141,6 +141,8 @@ struct tca8418_keypad {
struct i2c_client *client;
struct input_dev *input;
+ struct delayed_work tca8418_work;
+ struct wake_lock w_wake_lock;
#ifdef CONFIG_HAS_EARLYSUSPEND
struct early_suspend early_suspend;
#endif
@@ -188,6 +190,7 @@ static int tca8418_read_byte(struct tca8418_keypad *keypad_data,
return 0;
+#if 1
[函数描述] 把从寄存器里面读出来的值进行转化 5X6 原本应该读出来的值是 0~29 但是现在值不正确
[作者]韦启发
@@ -260,42 +263,17 @@ static void tca8418_read_keypad(struct tca8418_keypad *keypad_data)
input_sync(keypad_data->input);
+#endif
* Threaded IRQ handler and this can (and will) sleep.
static irqreturn_t tca8418_irq_handler(int irq, void *dev_id)
struct tca8418_keypad *keypad_data = dev_id;
- u8 reg;
- int error;
- enable_irq_wake(irq);
- printk("%sn", __FUNCTION__);
- error = tca8418_read_byte(keypad_data, REG_INT_STAT, ®);
- if (error) {
- dev_err(&keypad_data->client->dev,
- "unable to read REG_INT_STATn");
- goto exit;
+ printk("%sn",__func__);
+ enable_irq_wake(irq);/*深度休眠唤醒*/
- //printk("%s, reg = %dn", __FUNCTION__, reg);
- if (reg & INT_STAT_OVR_FLOW_INT)
- dev_warn(&keypad_data->client->dev, "overflow occurredn");
- if (reg & INT_STAT_K_INT)
- tca8418_read_keypad(keypad_data);
-exit:
- /* Clear all interrupts, even IRQs we didn't check (GPI, CAD, LCK) */
- //printk("%s failedn", __FUNCTION__);
- reg = 0xff;
- error = tca8418_write_byte(keypad_data, REG_INT_STAT, reg);
- if (error)
- "unable to clear REG_INT_STATn");
+ schedule_delayed_work(&keypad_data->tca8418_work,0);/*延迟启动中断队列*/
return IRQ_HANDLED;
#ifdef CONFIG_PM_SLEEP
@@ -344,7 +322,8 @@ static int __devinit tca8418_configure(struct tca8418_keypad *keypad_data)
printk("tca8418_configure failen");
return -ENODEV;
+ error |= tca8418_read_byte(keypad_data, REG_CFG, ®_r);/*键盘读寄存器,用来确认设置的是否正确*/
+ printk("%s REG_CFG[0x%x]=[0x%x]n",__func__,REG_CFG,reg_r);
/* Assemble a mask for row and column registers */
reg = ~(~0 << keypad_data->rows);
@@ -373,6 +352,53 @@ static int __devinit tca8418_configure(struct tca8418_keypad *keypad_data)
return error;
+static void tca8418_key_keypad_data(struct work_struct *work)
+ struct tca8418_keypad *keypad_data = container_of((struct delayed_work*)work, struct tca8418_keypad,tca8418_work);
+ u8 reg;
+ int error;
+ wake_lock(&keypad_data->w_wake_lock);/*使能唤醒锁*/
+ disable_irq_nosync(keypad_data->irq);/*屏蔽中断*/
+ printk("%s startn", __FUNCTION__);
+ error = tca8418_read_byte(keypad_data, REG_INT_STAT, ®);
+ if (error) {
+ dev_err(&keypad_data->client->dev,
+ "unable to read REG_INT_STATn");
+ goto exit;
+ else
+ printk("%s reg = %dn",__func__, reg);
+ if (reg & INT_STAT_OVR_FLOW_INT)
+ dev_warn(&keypad_data->client->dev, "overflow occurredn");
+ if (reg & INT_STAT_K_INT)
+ tca8418_read_keypad(keypad_data);
+exit:
+ /* Clear all interrupts, even IRQs we didn't check (GPI, CAD, LCK) */
+ //printk("%s failedn", __FUNCTION__);
+ reg = 0xff;
+ error = tca8418_write_byte(keypad_data, REG_INT_STAT, reg);
+ if (error){
+ dev_err(&keypad_data->client->dev,"unable to clear REG_INT_STATn");
+ if(error)
+ schedule_delayed_work(&keypad_data->tca8418_work,usecs_to_jiffies(300));/*延迟300ms启动中断队列*/
+ printk("%s unable to clear REG_INT_STAT againn",__func__);
+ }else{
+ printk("%sn clear REG_INT_STAT success",__func__);
+ printk("%s endn", __FUNCTION__);
+ enable_irq(keypad_data->irq);/*重新开启中断*/
+ wake_unlock(&keypad_data->w_wake_lock);/*屏蔽唤醒锁*/
static int __devinit tca8418_keypad_probe(struct i2c_client *client,
const struct i2c_device_id *id)
@@ -496,6 +522,9 @@ static int __devinit tca8418_keypad_probe(struct i2c_client *client,
if (pdata->irq_is_gpio)
client->irq = gpio_to_irq(client->irq);
+ /*初始化wakelock锁,工作队列,和申请中断*/
+ wake_lock_init(&keypad_data->w_wake_lock, WAKE_LOCK_SUSPEND, "tca8418_wakelock");
+ INIT_DELAYED_WORK(&keypad_data->tca8418_work,tca8418_key_keypad_data);
error = request_threaded_irq(client->irq, NULL, tca8418_irq_handler,
IRQF_TRIGGER_FALLING,
更多回帖
