工程资源中心
直播中
石俊梅
8年用户 136经验值
私信 关注
[电源设计]
使用SEPIC拓扑的10节锂离子电池充电器设计包括BOM及层图
            This battery charger reference design uses a SEPIC topology. The input voltage range is 17V to 21V and is designed for a maximum load current of 600mA. The output voltage can range from 13V to 41V and is inversely proportional to the load current (CV charging method).
主要特色
  • CV charge method
  • Supports ultra-wide battery voltage range
  • Adjustable maximum load current
  • Low cost solutioin
  • Low input and output ripple
  • Design has been built and tested
更多回帖
