工程资源中心
直播中
王盼盼
7年用户 170经验值
私信 关注
[电源设计]
提供恒压恒流的快速充电适配器解决方案包括BOM及层图
The PMP40060 is a fast charger solution with secondary-side regulation UCC28740DR which provides Constant-Voltage Constant-Current feature. The design supports 3.5V 7A lower output voltage closely to battery voltage and also 5.5V 7A output power level. This output performance will enable direct  (...)
主要特色
  • Valley switching operation and VS balance S.R flyback
  • System level solution for cable impedance detection and BAT OVP co-working with BQ2587x
  • 5V2A normal output and compliant with TI fast charge through D+/D-
  • One or two type-C optional
  • Vbus adjustable with 10mV/step resolution
更多回帖
