None
以上来自于谷歌翻译
以下为原文
Hi,
This week we had update the graphicdriver on our Xendesktops. The VDI are updated whit the Machine Crea
ting System and all have the same configuration. On 2 Xendesktops AutoCad use the new hardware driver and on the other AutoCad use the software driver. Why? Befor update it was working.
XenServer 6.5 SP1
XenDesktop 7.6 SP3
Windows 7 pro
grep -i "vmiop" /var/log/messages
Jan 4 09:40:24 srvgexen01 vgpu-98[24666]: notice: vmiop-env: guest_max_gpfn:0x20f000
Jan 4 09:40:24 srvgexen01 vgpu-98[24666]: notice: vmiop_log: gpu-pci-id : 0000:0b:00.0
Jan 4 09:40:24 srvgexen01 vgpu-98[24666]: notice: vmiop_log: vgpu_type : quadro
Jan 4 09:40:24 srvgexen01 vgpu-98[24666]: notice: vmiop_log: Framebuffer: 0x38000000
Jan 4 09:40:24 srvgexen01 vgpu-98[24666]: notice: vmiop_log: Virtual Device Id: 0x11B0:0x101A
Jan 4 09:40:24 srvgexen01 vgpu-98[24666]: notice: vmiop_log: ######## vGPU Manager Information: ########
Jan 4 09:40:24 srvgexen01 vgpu-98[24666]: notice: vmiop_log: Driver Version: 352.70
Jan 4 09:40:24 srvgexen01 vgpu-98[24666]: notice: vmiop_log: VGX Version: 3.0
Jan 4 09:40:24 srvgexen01 vgpu-98[24666]: notice: vmiop_log: Init frame copy engine: syncing...
Jan 4 09:42:57 srvgexen01 vgpu-98[24666]: notice: vmiop_log: ######## Guest NVIDIA Driver Information: ########
Jan 4 09:42:57 srvgexen01 vgpu-98[24666]: notice: vmiop_log: Driver Version: 354.56
Jan 4 09:42:57 srvgexen01 vgpu-98[24666]: notice: vmiop_log: VGX Version: 3.0
Jan 4 11:08:43 srvgexen01 vgpu-99[23698]: notice: vmiop-env: guest_max_gpfn:0x3cf000
Jan 4 11:08:43 srvgexen01 vgpu-99[23698]: notice: vmiop_log: gpu-pci-id : 0000:29:00.0
Jan 4 11:08:43 srvgexen01 vgpu-99[23698]: notice: vmiop_log: vgpu_type : quadro
Jan 4 11:08:43 srvgexen01 vgpu-99[23698]: notice: vmiop_log: Framebuffer: 0x38000000
Jan 4 11:08:43 srvgexen01 vgpu-99[23698]: notice: vmiop_log: Virtual Device Id: 0x11B0:0x101A
Jan 4 11:08:43 srvgexen01 vgpu-99[23698]: notice: vmiop_log: ######## vGPU Manager Information: ########
Jan 4 11:08:43 srvgexen01 vgpu-99[23698]: notice: vmiop_log: Driver Version: 352.70
Jan 4 11:08:43 srvgexen01 vgpu-99[23698]: notice: vmiop_log: VGX Version: 3.0
Jan 4 11:08:43 srvgexen01 vgpu-99[23698]: notice: vmiop_log: Init frame copy engine: syncing...
Jan 4 11:10:01 srvgexen01 vgpu-99[23698]: notice: vmiop_log: ######## Guest NVIDIA Driver Information: ########
Jan 4 11:10:01 srvgexen01 vgpu-99[23698]: notice: vmiop_log: Driver Version: 354.56
Jan 4 11:10:01 srvgexen01 vgpu-99[23698]: notice: vmiop_log: VGX Version: 3.0
Jan 4 11:38:35 srvgexen01 vgpu-98[24666]: notice: vmiop-env: guest increased max gpfn to :0x21efff
Jan 4 11:49:53 srvgexen01 vgpu-88[25498]: notice: vmiop-env: guest increased max gpfn to :0x3defff
Jan 4 12:11:48 srvgexen01 xenstored: D86 write data/report_clipboard grep -i "vmiop" /var/log/messages
[root@srvgexen01 ~]# nvidia-smi
Mon Jan 4 16:14:54 2016
| NVIDIA-SMI 352.70 Driver Version: 352.70 |
| GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. |
| 0 GRID K2 On | 0000:0A:00.0 Off | Off |
| N/A 36C P8 28W / 117W | 3743MiB / 4095MiB | 1% Default |
| 1 GRID K2 On | 0000:0B:00.0 Off | Off |
| N/A 41C P8 28W / 117W | 2803MiB / 4095MiB | 15% Default |
| 2 GRID K2 On | 0000:29:00.0 Off | Off |
| N/A 41C P8 29W / 117W | 3730MiB / 4095MiB | 1% Default |
| 3 GRID K2 On | 0000:2A:00.0 Off | Off |
| N/A 46C P8 28W / 117W | 3728MiB / 4095MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 9771 C+G /usr/lib64/xen/bin/vgpu 896MiB |
| 0 21196 C+G /usr/lib64/xen/bin/vgpu 896MiB |
| 0 25498 C+G /usr/lib64/xen/bin/vgpu 896MiB |
| 0 32282 C+G /usr/lib64/xen/bin/vgpu 896MiB |
| 1 15550 C+G /usr/lib64/xen/bin/vgpu 896MiB |
| 1 23428 C+G /usr/lib64/xen/bin/vgpu 896MiB |
| 1 29733 C+G /usr/lib64/xen/bin/vgpu 896MiB |
| 2 10688 C+G /usr/lib64/xen/bin/vgpu 896MiB |
| 2 11987 C+G /usr/lib64/xen/bin/vgpu 896MiB |
| 2 12761 C+G /usr/lib64/xen/bin/vgpu 896MiB |
| 2 18527 C+G /usr/lib64/xen/bin/vgpu 896MiB |
| 3 14369 C+G /usr/lib64/xen/bin/vgpu 896MiB |
| 3 16455 C+G /usr/lib64/xen/bin/vgpu 896MiB |
| 3 22391 C+G /usr/lib64/xen/bin/vgpu 896MiB |
| 3 29673 C+G /usr/lib64/xen/bin/vgpu 896MiB |
On the XenDesktop whit Autocad hardware and AutoCad is running:
L:>"C:Program FilesNVIDIA CorporationNVSMInvidia-smi.exe"
Mon Jan 04 14:46:00 2016
| NVIDIA-SMI 354.56 Driver Version: 354.56 |
| GPU Name TCC/WDDM | Bus-Id Disp.A | Volatile Uncorr. ECC |
| 0 GRID K240Q WDDM | 0000:00:0B.0 On | N/A |
| N/A N/A P8 N/A / N/A | 905MiB / 1024MiB | N/A Prohibited |
| 0 744 C+G Insufficient Permissions N/A |
| 0 20244 C+G ...CAD LT 2016acwebbrowseracwebbrowser.exe N/A |
| 0 24768 C+G ...esRhinoceros 5 (64-bit)SystemRhino.exe N/A |
| 0 25056 C+G ...ppleInternet ServicesiCloudServices.exe N/A |
| 0 26496 C+G ...e Desktop CommonHEXAdobe CEF Helper.exe N/A |
| 0 26996 C+G ...m Files (x86)Mozilla Firefoxfirefox.exe N/A |
| 0 29908 C+G ...s (x86)LibreOffice 5programsoffice.bin N/A |
| 0 30552 C+G ...FilesAutodeskAutoCAD LT 2016acadlt.exe N/A |
On the XenDesktop whit AutoCad software driver and AutoCad is running:
L:Usersg.dubois>"C:Program FilesNVIDIA CorporationNVSMInvidia-smi.exe"
Mon Jan 04 16:08:13 2016
| N/A N/A P8 N/A / N/A | 296MiB / 1024MiB | N/A Prohibited |
| 0 748 C+G Insufficient Permissions N/A |
| 0 8120 C+G ...e Desktop CommonHEXAdobe CEF Helper.exe N/A |
| 0 11492 C+G ...m Files (x86)Mozilla Firefoxfirefox.exe N/A |
| 0 31860 C+G ...s (x86)LibreOffice 5programsoffice.bin N/A |
| 0 34004 C+G ...x86)GoogleChromeApplicationchrome.exe N/A |
Best regards
Simon Schmidig
