ARM技术论坛
直播中
兰凤送
7年用户 601经验值
擅长:电源/新能源 嵌入式技术 接口/总线/驱动
私信 关注
[资料]
IMX8M-CB314 Hardware
MY-IMX8M-CB314 Hardware Introduction[size=0.875em]
目录[size=12.502px] [隐藏]
  • 1MY-iMX8M_CB314 view
    • 1.1Front view
    • 1.2Rear view
    • 1.3Size
  • 2MY-iMX8M_CB314 parameter
    • 2.1Master control platform detailed parameters
    • 2.2Hardware configuration
    • 2.3Temperature range
      • 2.3.1Operating temperature
      • 2.3.2Storage temperature
    • 2.4Operating system supported
    • 2.5Hardware interface
    • 2.6Power Supply
    • 2.7Definition of pin
    • 2.8Instruction of detailed function of pins
      • 2.8.1form 1
      • 2.8.2form 2
MY-iMX8M_CB314 view
Front view
Rear view
Size
  • 1.Heterogeneous multi-core, quad-core CortexTM-A53, single Cortex-M4, up to 1.5GHz;
  • 2. OpenGL/E 3.1,OpenGL 3.0,Vulkan,OpenCL 1.1;
  • 3. Dual independent display,MIPI-DSI,HDMI 2.0a;
  • 4. Support VP9/H265/H264/MPEG2/MPEG4p2/VC1/VP8/RV9/AVS/AVS+/H263/DIVX and MJPEG-8x8 video decoding, 4K, up to 60Hz;
  • 5. 6xI2S/SAI (20+ channels, 32 bits @384KHz per channel), SPDIF Tx/Rx, DSD512;
  • 6. Dual camera support, mipi-csi (every 4 channels);
  • 7. Support LPDDR4, DDR4, DDR3L, Quad SPI with XIP;
  • 8. Dual USB 3.0 C with PHY;
  • 9. Provide double PCIe of L1 substate with quick wake function from low power consumption mode.
  • 10.Gigabit Ethernet controller with AVB and EEE support;
  • 11.Support MLC NAND Flash, EMMC 5.0;
Cord board model
CPU
Memory
Storage)
boot mode
burning mode
others
MY-IMX8M_CB314MIMX8MQ6DVAJZAA1G/2GeMMC:4G~32GeMMCDial-up entrystandard configuration:memory 2G,storage 16G
Temperature rangeOperating temperature
  • Commercial grade:
0°C ~ +90 °C
Storage temperature-40°C ~ +125°C
  • Kernel: Linux-4.9.88
  • Kernel:Andorid 8.0
  • Kernel:FreeRTOS
Hardware interface
Display moduleHDMI1wayHDMI2.0a , up to 4096x2160 at 60Hz
MIPI-DSI1way4 channels, up to 1920x1080 at 60Hz
Camera moduleMIPI-CSI2way4-lane each, 5M pixel at 15 fps ,1.5 Gbps
EthernetRGMII1waysupport 10/100/1000Mbps
AudioSAI6wayover 20 channels of audio
PCI ExpressPCIe2way1-lane each
StorageSD/MMCcard2way4/8-bit
Nand Flash1way8-bit
USBUSB 2.02way480 Mbps
USB 3.02way5.0 Gbps
SPISPI3wayup to 52 Mbit/s
QSPIQSPI1waysupport up to 80 MHz SDR mode and 50 MHz DDR mode
UARTUART4wayup to 4 Mbps
PWMPWM4way16-bit
12C12C4wayup to 100 kbits/s
DebugJTAG1wayJTAG Debug
Power Supply
5V input
Definition of pin
Pin NO.
Pin Name
Pin voltage
Pin NO.
Pin Name
Pin voltage
P1GND0VS1GND0V
P2GND0VS2RGMII_INT1.8V
P3GND0VS3NFC_WAKE1.8V
P4RGMII_RXD23.3VS4NFC_REG_ON3.3V
P5RGMII_TXD13.3VS5SPI0_CSn03.3V
P6RGMII_RXD33.3VS6SPI0_CSn03.3.V
P7RGMII_RXDV3.3VS7NFC_HOST_WAKE3.3V
P8RGMII_TXD03.3VS8SDMMC_D33.3V
P9RGMII_TXEN3.3VS9SDMMC_CMD3.3V
P10RGMII_RXER3.3VS10SDMMC_D23.3V
P11GND0VS11SDMMC_DET3.3V
P12RGMII_CLK3.3VS12SDMMC_D13.3V
P13GND0VS13SDMMC_CLK3.3V
P14RGMII_RXD03.3VS14SDMMC_D03.3V
P15RGMII_RXD13.3VS15SDMMC_WP3.3V
P16RGMII_TXD23.3VS16FLASH0_ALE1.8V
P17RGMII_TXD33.3VS17FLASH0_CLE1.8V
P18RGMII_TXCLK3.3VS18FLASH0_RDY1.8V
P19RGMII_RXCLK3.3VS19FLASH0_CS01.8V
P20RGMII_MDC3.3VS20MIPI_RST1.8V
P21RGMII_MDIO3.3VS21UART1_CTS3.3V
P22RGMII_RST3.3VS22UART1_RX3.3V
P23RGMII_CRS3.3VS23UART1_TX3.3V
P24GND0VS24UART1_RTS3.3V
P25SDIO0_D32.2VS25GPIO5_C23.3V
P26SDIO0_CMD2.2VS26SPI0_TXD3.3V
P27SDIO0_D02.2VS27SPI0_RXD3.3V
P28SDIO0_D22.2VS28SPI0_CSn13.3V
P29SDIO0_D12.2VS29WIFI_REG_ON2.2V
P30SDIO0_CLK2.2VS30BT_HOST_WAKE2.2V
P31GND0VS31GPIO4_D32.2V
P32GND0VS32WIFI_HOST_WAKE2.2V
P33GND0VS33BT_RST2.2V
P34GND0VS34BT_WAKE2.2V
P35GND0VS35GND0V
P36GND0VS36GND0V
P37UART0_CTS2.2VS37I2S0_CLK3.3V
P38UART0_RTS2.2VS38GND0V
P39UART0_TXD2.2VS39I2S0_SCLK3.3V
P40UART0_RXD2.2VS40I2S0_SDI3.3V
P41I2C2_SCL3.3VS41I2S0_LRCK_TX3.3V
P42I2C2_SDA3.3VS42I2S0_LRCK_RX3.3V
P43SPDIF_TX3.3VS43I2S0_SDO03.3V
P44GND0VS44I2S0_SDO33.3V
P45EDP_TX0P1.8VS45I2S0_SDO23.3V
P46EDP_TX0N1.8VS46I2S0_SDO13.3V
P47GND0VS47HDMI_HPD1.8V
P48EDP_TX1P1.8VS48GND0V
P49EDP_TX1N1.8VS49HDMI_TXCP1.8V
P50GND0VS50HDMI_TXCN1.8V
P51EDP_TX2P1.8VS51GND0V
P52EDP_TX2N1.8VS52HDMI_TX0P1.8V
P53GND0VS53HDMI_TX0N1.8V
P54EDP_TX3P1.8VS54GND0V
P55EDP_TX3N1.8VS55HDMI_TX1N1.8V
P56GND0VS56HDMI_TX1P1.8V
P57EDPAUXP1.8VS57GND0V
P58EDPAUXN1.8VS58HDMI_TX2N1.8V
P59GND0VS59HDMI_TX2P1.8V
P60MIPI_RX_D0N1.8VS60GND0V
P61MIPI_RX_D0P1.8VS61MIPI_TX/RX_D0P1.8V
P62GND0VS62MIPI_TX/RX_D0N1.8V
P63MIPI_RX_D1N1.8VS63GND0V
P64MIPI_RX_D1P1.8VS64MIPI_TX/RX_D1P1.8V
P65GND0VS65MIPI_TX/RX_D1N1.8V
P66MIPI_RX_CLKN1.8VS66GND0V
P67MIPI_RX_CLKP1.8VS67MIPI_TX/RX_CLKP1.8V
P68GND0VS68MIPI_TX/RX_CLKN1.8V
P69MIPI_RX_D2N1.8VS69GND1.8V
P70MIPI_RX_D2P1.8VS70MIPI_TX/RX_D2P1.8V
P71GND0VS71MIPI_TX/RX_D2N1.8V
P72MIPI_RX_D3N1.8VS72GND0V
P73MIPI_RX_D3P1.8VS73MIPI_TX/RX_D3P1.8V
P74GND0VS74MIPI_TX/RX_D3N1.8V
P75GND0VS75GND0V
P76LVDS_D4P3.3VS76GND0V
P77LVDS_D4N3.3VS77GND0V
P78LVDS_D3P3.3VS78MIPI_TX_D1P1.8V
P79LVDS_D3N3.3VS79MIPI_TX_D1N1.8V
P80LVDS_D2P3.3VS80GND0V
P81LVDS_D2N3.3VS81MIPI_TX_D0P1.8V
P82LVDS_CLK0P3.3VS82MIPI_TX_D0N1.8V
P83LVDS_CLK0N3.3VS83GND0V
P84LVDS_D1P3.3VS84MIPI_TX_CLKP1.8V
P85LVDS_D1N3.3VS85MIPI_TX_CLKN1.8V
P86LVDS_D0P3.3VS86GND0V
P87LVDS_D0N3.3VS87MIPI_TX_D2P1.8V
P88LVDS_D8P3.3VS88MIPI_TX_D2N1.8V
P89LVDS_D8N3.3VS89GND0V
P90LVDS_D9N3.3VS90MIPI_TX_D3P1.8V
P91LVDS_D9P3.3VS91MIPI_TX_D3N1.8V
P92LVDS_D7N3.3VS92GND0V
P93LVDS_D7P3.3VS93CIF_D51.8V
P94LVDS_CLK1N3.3VS94CIF_D11.8V
P95LVDS_CLK1P3.3VS95CIF_D21.8V
P96LVDS_D6P3.3VS96CIF_D31.8V
P97LVDS_D6N3.3VS97CIF_D01.8V
P98LVDS_D5P3.3VS98CIF_CLK1.8V
P99LVDS_D5N3.3VS99CIF_D71.8V
P100LCDC0_VSYNC3.3VS100CIF_D41.8V
P101GND0VS101CIF_D61.8V
P102LCDC0_DCLK3.3VS102CIF_PDN11.8V
P103GND0VS103CIF_CLKO1.8V
P104LCDC0_HSYNC3.3VS104CIF_VSYNC1.8V
P105LCDC0_DEN3.3VS105CIF_PDN01.8V
P106I2C3_SCL1.8VS106CIF_HREF1.8V
P107I2C3_SDA1.8VS107GND0V
P108GPIO2_B61.8VS108UART3_TX3.3V
P109GPIO2_B51.8VS1095V_DRV3.3V
P110GND0VS110GYR_INT3.3V
P111ADC_IN01.8VS111EDP_BL3.3V
P112ADC_IN21.8VS112UART3_CTS3.3V
P113RECOVER1.8VS113FLASH_TRIGOUT3.3V
P114GND0VS114LCDC_BL3.3V
P115EFUSE_PWR3.3VS115TOUCH_RST3.3V
P116PMUGPIO0_B53.3VS116LCD_EN3.3V
P117OTG_VBUS_DRV3.3VS117LCD_RST3.3V
P118PHONE_CTL3.3VS118TOUCH_INT3.3V
P119UART2_RXD3.3VS119I2C1_SCL3.3V
P120UART2_TXD3.3VS120I2C1_SDA3.3V
P121HDMI_CEC3.3VS121GSEN_INT3.3V
P122SPK_CTL3.3VS122SPI2_MISO3.3V
P123FLASH_EN3.3VS123SPI2_CLK3.3V
P124UART3_RTS3.3VS124SPI2_nCS03.3V
P125EDP_HPD3.3VS125SPI2_MOSI3.3V
P126UART3_RX3.3VS126JTAG_TCK3.3V
P127BL_EN3.3VS127JTAG_TDO3.3V
P128LED43.3VS128JTAG_TDI3.3V
P129LED33.3VS129JTAG_TMS3.3V
P130LED23.3VS130nJTAG_TRST3.3V
P131LED13.3VS131USB2UART_nRST3.3V
P132KEY_VOL_N3.3VS132OTG_ID3.3V
P133KEY_VOL_P3.3VS133OTG_DET3.3V
P134I2C5_SDA3.3VS134GND0V
P135I2C5_SCL3.3VS135HOST1_DP5V
P136I2C4_SDA3.3VS136HOST1_DM5V
P137I2C4_SCL3.3VS137GND0V
P138PWR_KEY5VS138HOST2_DP5V
P139RESET_KEY5VS139HOST2_DM5V
P140PMIC_PWRON5VS140GND0V
P141OTP_RESET3.3VS141OTG_DP5V
P142HSIC_STROBE1.0VS142OTG_DM5V
P143HSIC_DATA1.0VS143GND
P144RTC_CLKOUT232.768KHzS144VCC_EFUSE3.0V
P145GND0VS145VCCA_333.3V
P146GND0VS146VCC18_DVP1.8V
P147GND0VS147VCC28_DVP2.8V
P148GND0VS148RTC_PWRIN3.4V
P149GND0VS149VCC_181.8V
P150GND0VS150VCC_IO3.3V
P151GND0VS151VCC_IO3.3V
P152GND0VS1525VIN5V
P153GND0VS1535VIN5V
P154GND0VS1545VIN5V
P155GND0VS1555VIN5V
P156GND0VS1565VIN5V
S1575VIN5V
S1585VIN5V
Instruction of detailed function of pinsform 1
Pin NO.
Pin Name
CPU Ball Name
Functional description
Pin voltage
P15V_CORE————5V(input)
P2
P3
P4
P5
P6GND——————
P7
P8
P9
P10
P11CSI_P1_DP3D21MIPI_CSI1_D3_P1.8V
P12CSI_P1_DN3C21MIPI_CSI1_D3_N
P13GND——————
P14CSI_P1_DP1D22MIPI_CSI1_D1_P1.8V
P15CSI_P1_DN1C22MIPI_CSI1_D1_N
P16GND——————
P17CSI_P1_DP2C23MIPI_CSI1_D2_P1.8V
P18CSI_P1_DN2B24MIPI_CSI1_D2_N
P19GND——————
P20CSI_P1_DP0B23MIPI_CSI1_D0_P1.8V
P21CSI_P1_DN0A23MIPI_CSI1_D0_N
P22GND——————
P23CSI_P1_CKPB22MIPI_CSI1_CLK_P1.8V
P24CSI_P1_CKNA22MIPI_CSI1_CLK_N
P25GND——————
P26CSI_P2_DP2B21MIPI_CSI2_D2_P1.8V
P27CSI_P2_DN2A21MIPI_CSI2_D2_N
P28GND——————
P29CSI_P2_DP1B20MIPI_CSI2_D1_P1.8V
P30CSI_P2_DN1A20MIPI_CSI2_D1_N
P31GND——————
P32CSI_P2_CKPB19MIPI_CSI2_CLK_P1.8V
P33CSI_P2_CKNA19MIPI_CSI2_CLK_N
P34GND——————
P35CSI_P2_DN3C19MIPI_CSI2_D3_N1.8V
P36CSI_P2_DP3D19MIPI_CSI2_D3_P
P37GND——————
P38CSI_P2_DP0D20MIPI_CSI2_D0_P1.8V
P39CSI_P2_DN0C20MIPI_CSI2_D0_N
P40GND——————
P41
P42
P43UART3_CTSB4ECSPI1_MISO3.3V
UART3_CTS_B
GPIO5_IO08
P44UART3_RTSD4ECSPI1_SS03.3V
UART3_RTS_B
GPIO5_IO09
P45UART3_TXDB7UART3_TXD3.3V
UART1_RTS_B
GPIO5_IO27
P46UART3_RXDA6UART3_RX3.3V
UART1_CTS_B
GPIO5_IO26
P47UART2_TXDD6UART2_TX3.3V
ECSPI3_SS0
GPIO5_IO25
P48UART2_RXDB6UART2_RX3.3V
ECSPI3_MISO
GPIO5_IO24
P49UART1_TXDD6UART1_TX3.3V
ECSPI3_MOSI
GPIO5_IO23
P50UART1_RXDC7UART1_RX3.3V
ECSPI3_SCLK
GPIO5_IO22
P51GND——————
P52SPDIF_EXT_CLKE6SPDIF1_EXT_CLK3.3V
PWM1_OUT
GPIO5_IO05
P53GND——————
P54SPDIF_EXT_TXF6SPDIF1_OUT3.3V
PWM3_OUT
GPIO5_IO03
P55SPDIF_RXG6SPDIF1_IN3.3V
PWM2_OUT
GPIO5_IO04
P56GND——————
P57SAI1_MCLKA3SAI1_MCLK3.3V
SAI5_MCLK
SAI1_TX_BCLK
GPIO4_IO20
P58GND——————
P59SAI1_TXD6B3SAI1_TX_DATA63.3V
SAI6_RX_SYNC
SAI6_TX_SYNC
CORESIGHT_TRACE14
GPIO4_IO18
SRC_BOOT_CFG14
P60SAI1_TXD2B2SAI1_TX_DATA33.3V
SAI5_TX_DATA3
CORESIGHT_TRACE11
GPIO4_IO15
SRC_BOOT_CFG11
P61SAI1_TXD5C2SAI1_TX_DATA53.3V
SAI6_RX_DATA0
SAI6_TX_DATA0
CORESIGHT_TRACE13
GPIO4_IO17
SRC_BOOT_CFG13
P62SAI1_TXD7C1SAI1_TX_DATA73.3V
SAI6_MCLK
CORESIGHT_TRACE15
GPIO4_IO19
SRC_BOOT_CFG15
P63SAI1_TXD4D2SAI1_TX_DATA43.3V
SAI6_RX_BCLK
SAI6_TX_BCLK
CORESIGHT_TRACE12
GPIO4_IO16
SRC_BOOT_CFG12
P64SAI1_TXD3D1SAI1_TX_DATA33.3V
SAI5_TX_DATA3
CORESIGHT_TRACE11
GPIO4_IO15
SRC_BOOT_CFG11
P65SAI1_TXD1E2SAI1_TX_DATA13.3V
SAI5_TX_DATA1
CORESIGHT_TRACE9
GPIO4_IO13
SRC_BOOT_CFG9
P66SAI1_TXCE1SAI1_TX_BCLK3.3V
SAI5_TX_BCLK
CORESIGHT_EVENTI
GPIO4_IO11
P67SAI1_TXD0F2SAI1_TX_DATA03.3V
SAI5_TX_DATA0
CORESIGHT_TRACE8
GPIO4_IO12
SRC_BOOT_CFG8
P68SAI1_RXD5F1SAI1_RX_DATA53.3V
SAI6_TX_DATA0
SAI6_RX_DATA0
SAI1_RX_SYNC
CORESIGHT_TRACE5
GPIO4_IO07
SRC_BOOT_CFG5
P69SAI1_RXD6G2SAI1_RX_DATA63.3V
SAI6_TX_SYNC
SAI6_RX_SYNC
CORESIGHT_TRACE6
GPIO4_IO08
SRC_BOOT_CFG6
P70SAI1_RXD7G1SAI1_RX_DATA73.3V
SAI6_MCLK
SAI1_TX_SYNC
SAI1_TX_DATA4
CORESIGHT_TRACE7
GPIO4_IO09
SRC_BOOT_CFG7
P71SAI1_RXD2H2SAI1_RX_DATA23.3V
SAI5_RX_DATA2
SAI5_RX_DATA2
GPIO4_IO04
SRC_BOOT_CFG2
P72SAI1_TXFSH1SAI1_TX_SYNC3.3V
SAI5_TX_SYNC
CORESIGHT_EVENTO
GPIO4_IO10
P73SAI1_RXD3J2SAI1_RX_DATA33.3V
SAI5_RX_DATA3
CORESIGHT_TRACE3
GPIO4_IO05
SRC_BOOT_CFG3
P74GND——————
P75
P76SAI1_RXD4G2SAI1_RX_DATA43.3V
SAI6_TX_BCLK
SAI6_RX_BCLK
CORESIGHT_TRACE4
GPIO4_IO06
SRC_BOOT_CFG4
P77SAI1_RXD0K2SAI1_RX_DATA03.3V
SAI5_RX_DATA0
CORESIGHT_TRACE0
GPIO4_IO00
SRC_BOOT_CFG0
P78SAI1_RXCK1SAI1_RX_BCLK3.3V
SAI5_RX_BCLK
CORESIGHT_TRACE_CTL
GPIO4_IO01
P79SAI1_RXD1L2SAI1_RX_DATA13.3V
SAI5_RX_DATA1
CORESIGHT_TRACE1
GPIO4_IO03
SRC_BOOT_CFG1
P80SAI1_RXFSL1SAI1_RX_SYNC3.3V
SAI5_RX_SYNC
CORESIGHT_TRACE_CLK
GPIO4_IO00
P81GND——————
P82HDMI_DDC_SDAP3HDMI_DDC_SDA1.8V
P83HDMI_DDC_SCLP3HDMI_DDC_SCL
P84GND——————
P85HDMI_CLKNM2HDMI_TX_N_LN_31.8V
P86HDMI_CLKPM1HDMI_TX_P_LN_3
P87GND——————
P88HDMI_TXN2N1HDMI_TX_N_LN_21.8V
P89HDMI_TXP2N2HDMI_TX_P_LN_2
P90GND——————
P91HDMI_TXN0T2HDMI_TX_N_LN_01.8V
P92HDMI_TXP0T1HDMI_TX_P_LN_0
P93GND——————
P94HDMI_TXP1U2HDMI_TX_P_LN_11.8V
P95HDMI_TXN1U1HDMI_TX_N_LN_1
P96GND——————
P97HDMI_AUXNV2HDMI_AUX_N1.8V
P98HDMI_TXN1V1HDMI_AUX_P
P99GND——————
P100HDMI_HPDW2HDMI_HPD1.8V
P101GND——————
P102HDMI_CECW3HDMI_CEC1.8V
P103JTAG_NTRSTU6JTAG_TRST_B3.3V
P104JTAG_TDOU5JTAG_TDO3.3V
P105JTAG_TCKT5JTAG_TCK3.3V
P106JTAG_TMSV5JTAG_TMS3.3V
P107JTAG_TDIW5JTAG_TDI3.3V
P108I2C2_SDAF7I2C2_SDA3.3V
ENET1_1588_EVENT1_OUT
GPIO5_IO17
P109I2C2_SCLG7I2C2_SCL3.3V
ENET1_1588_EVENT1_IN
GPIO5_IO16
P110I2C1_SDAE8I2C1_SDA3.3V
ENET1_MDIO
GPIO5_IO15
P111I2C1_SCLE7I2C1_SCL3.3V
ENET1_MDC
GPIO5_IO14
P112I2C3_SCLG8I2C3_SCL3.3V
PWM4_OUT
GPT2_CLK
GPIO5_IO18
P113I2C3_SDAE9I2C3_SDA3.3V
PWM3_OUT
GPT3_CLK
GPIO5_IO19
P114GND——————
P115WL_REG_OND7UART4_TX3.3V
UART2_RTS_B
PCIE2_CLKREQ_B
GPIO5_IO29
P116WL_NPERSTC6UART4_RX3.3V
UART2_CTS_B
PCIE1_CLKREQ_B
GPIO5_IO28
P117WIFI_PCIE_NCLKREQ——————
P118PCIE1_NCLKREQF8I2C4_SCL3.3V
PWM2_OUT
PCIE1_CLKREQ_B
GPIO5_IO20
P119PCIE2_NCLKREQF9I2C4_SDA3.3V
PWM1_OUT
PCIE2_CLKREQ_B
GPIO5_IO21
P120PCIE_NCLKREQ——————
P121GND——————
P122PCIE2_RXPD25PCIE2_RXN_P3.3V
P123PCIE2_RXND24PCIE2_RXN_N
P124GND——————
P125PCIE2_REF_CLKN_CNF24PCIE2_REF_PAD_CLK_N3.3V
P126PCIE2_REF_CLKP_CNF25PCIE2_REF_PAD_CLK_P
P127GND——————
P128PCIE2_TXPE25PCIE2_TXN_P3.3V
P129PCIE2_TXNE24PCIE2_TXN_N
P130GND——————
P131
P132
P133
P134PCIE1_RXNH24PCIE1_RXN_N3.3V
P135PCIE1_RXPH25PCIE1_RXN_P
P136GND——————
P137PCIE1_TXNJ24PCIE1_TXN_N3.3V
P138PCIE1_TXPJ25PCIE1_TXN_P
P139GND——————
P140WIFI_PCIE_CLKN——————
P141WIFI_PCIE_CLKP——————
P142GND——————
P143
P144
P145
P146CLK1_PR23CLK1_P1.8V(input)
P147CLK1_NT23CLK1_N
P148GND——————
P149POR_BW20SRC_POR_B3.3V
P150WL_NWAKEM20RAWNAND_DQS3.3V
QSPI_A_DQS
GPIO3_IO14
P151WIFI_PCIE_CLKP——————
P152PMIC_STBY_REQV21CCM_PMIC_STBY_REQ3.3V
P153ONOFFW21XTALOSC_ONOFF3.3V
P154BOOT_MODE1V6SRC_BOOT_MODE13.3V
P155BOOT_MODE0W6SRC_BOOT_MODE03.3V
P156GND——————
form 2
Pin NO.
Pin Name
CPU Ball Name
Pin voltage
S15V_CORE————5V(input)
S2
S3
S4
S5
S6GND——————
S7
S8
S9
S10
S11VDD_PHY_3V3————3.3V(input)
S12
S13VDD_PHY_1V8————1.8V(input)
S14GND——————
S15
S16
S17DSI_DN2A18MIPI_DSI_D2_N1.8V
S18DSI_DP2B18MIPI_DSI_D2_P
S19GND——————
S20DSI_DN0A17MIPI_DSI_D0_N1.8V
S21DSI_DP0B17MIPI_DSI_D0_P
S22GND——————
S23DSI_DN1A16MIPI_DSI_D1_N1.8V
S24DSI_DP1B16MIPI_DSI_D1_P
S25GND——————
S26DSI_DN3A15MIPI_DSI_D3_N1.8V
S27DSI_DP3B15MIPI_DSI_D3_P
S28GND——————
S29DSI_CKPD16MIPI_DSI_CLK_P1.8V
S30DSI_CKNC16MIPI_DSI_CLK_N
S31GND——————
S32USB1_IDC16USB1_ID3.3V
S33USB1_DNB14USB1_DN3.3V
S34USB1_DPA14USB1_DP3.3V
S35USB1_VBUSD14USB1_VBUS3.3V
S36GND——————
S37USB1_TXNB13USB1_TXN3.3V
S38USB1_TXPA13USB1_TXP
S39GND——————
S40USB1_RXNB12USB1_RXN3.3V
S41USB1_RXPA12USB1_RXP
S42GND——————
S43USB2_IDC9USB2_ID3.3V
S44USB2_DNB10USB2_DN
S45USB2_DPA10USB2_DP3.3V
S46USB2_VBUSD9USB2_VBUS
S47GND——————
S48USB2_TXNB9USB2_TXN3.3V
S49USB2_TXPA9USB2_TXP
S50GND——————
S51USB2_RXNB8USB2_RXN3.3V
S52USB2_RXPA8USB2_RXP
S53GND——————
S54USB1_SS_SELK19RAWNAND_RE_B3.3V
QSPI_B_DQS
GPIO3_IO15
S55DSI_END5ECSPI1_SCLK3.3V
UART3_RX
GPIO5_IO06
S56PCIE_NDISC5ECSPI2_SCLK3.3V
UART4_RX
GPIO5_IO10
S57PCIE_NWAKEE5ECSPI2_MOSI3.3V
UART4_TX
GPIO5_IO11
S58BT_RF_KILLA5ECSPI2_SS03.3V
UART4_RTS_B
GPIO5_IO13
S59PCIE_NRSTB5ECSPI2_MISO3.3V
UART4_CTS_B
GPIO5_IO12
S60DSI_TS_NINTA4ECSPI1_MISO3.3V
UART3_TX
GPIO5_IO07
S61GND——————
S62SAI2_RXDH6SAI2_RX_DATA03.3V
SAI5_TX_DATA0
GPIO4_IO23
S63SAI2_TXDG5SAI2_TX_DATA03.3V
SAI5_TX_DATA3
GPIO4_IO26
S64SAI2_RXCH3SAI2_RX_BCLK3.3V
SAI5_TX_BCLK
GPIO4_IO22
S65SAI2_MCLKH5SAI2_MCLK3.3V
SAI5_MCLK
GPIO4_IO27
S66GND——————
S67SAI2_RXFSJ4SAI2_RX_SYNC3.3V
SAI5_TX_SYNC
GPIO4_IO21
S68SAI2_TXCJ5SAI2_TX_BCLK3.3V
SAI5_TX_DATA2
GPIO4_IO25
S69SAI2_TXFSH4SAI2_TX_SYNC3.3V
SAI5_TX_DATA1
GPIO4_IO24
S70GND——————
S71SAI3_RXFSG4SAI3_RX_SYNC3.3V
GPT1_CAPTURE1
SAI5_RX_SYNC
GPIO4_IO28
S72SAI3_RXDF3SAI3_RX_DATA03.3V
GPT1_COMPARE1
SAI5_RX_DATA0
GPIO4_IO30
S73SAI3_RXCF4SAI3_RX_BCLK3.3V
GPT1_CAPTURE2
SAI5_RX_BCLK
GPIO4_IO29
S74SAI3_TXDC3SAI3_TX_DATA03.3V
GPT1_COMPARE3
SAI5_RX_DATA3
GPIO5_IO01
S75GND——————
S76
S77SAI3_TXCC4SAI3_TX_BCLK3.3V
GPT1_COMPARE2
SAI5_RX_DATA2
GPIO5_IO00
S78SAI3_TXFSG3SAI3_TX_SYNC3.3V
GPT1_CLK
SAI5_RX_DATA1
GPIO4_IO31
S79SAI3_MCLKD3SAI3_MCLK3.3V
PWM4_OUT
SAI5_MCLK
GPIO5_IO02
S80GND——————
S81SAI5_MCLKK4SAI5_MCLK3.3V
SAI1_TX_BCLK
SAI4_MCLK
GPIO3_IO25
S82GND——————
S83SAI5_RXD3K5SAI5_RX_DATA33.3V
SAI1_TX_DATA5
SAI1_TX_SYNC
SAI5_TX_DATA0
GPIO3_IO24
S84SAI5_RXD1L4SAI5_RX_DATA13.3V
SAI1_TX_DATA3
SAI1_TX_SYNC
SAI5_TX_SYNC
GPIO3_IO22
S85GND——————
S86SAI5_RXCL5SAI5_RX_BCLK3.3V
SAI1_TX_DATA1
GPIO3_IO20
S87GND——————
S88SAI5_RXD2M4SAI5_RX_DATA23.3V
SAI1_TX_DATA4
SAI1_TX_SYNC
SAI5_TX_BCLK
GPIO3_IO23
S89SAI5_RXD0M5SAI5_RX_DATA03.3V
SAI1_TX_DATA2
GPIO3_IO21
S90SAI5_RXFSN4SAI5_RX_SYNC3.3V
SAI1_TX_DATA0
GPIO3_IO19
S91GND——————
S92
S93NWDOGR4GPIO1_IO023.3V
WDOG1_WDOG_B
WDOG1_WDOG_ANY
S94DSI_BL_PWMT7GPIO1_IO013.3V
PWM1_OUT
ANAMIX_REF_CLK_24M
CCM_EXT_CLK2
S95REF_CLK_32KT6GPIO1_IO003.3V
CCM_ENET_PHY_REF_CLK_ROOT
ANAMIX_REF_CLK_32K
CCM_EXT_CLK1
S96GND——————
S97CLKO_25MHZK7GPIO1_IO143.3V
USB2_OTG_PW
PWM3_OUT
CCM_CLKO1
S98CLKO2J6GPIO1_IO153.3V
USB2_OTG_OC
PWM4_OUT
CCM_CLKO2
S99ENET_WOLK7GPIO1_IO103.3V
USB1_OTG_ID
S100AUD_NMUTEN7GPIO1_IO083.3V
ENET1_1588_EVENT0_IN
USDHC2_RESET_B
S101PWM_LEDK6GPIO1_IO133.3V
USB1_OTG_OC
PWM2_OUT
S102ENET_NINTL6GPIO1_IO113.3V
USB2_OTG_ID
CCM_PMIC_READY
S103ENET_NRSTM6GPIO1_IO093.3V
ENET1_1588_EVENT0_OUT
SDMA2_EXT_EVENT0
S104IR_CAPL7GPIO1_IO123.3V
USB1_OTG_PWR
SDMA2_EXT_EVENT1
S105CSI_P1_PWDNP4GPIO1_IO033.3V
USDHC1_VSELECT
SDMA1_EXT_EVENT0
S106CSI_NRSTN5GPIO1_IO063.3V
ENET1_MDC
USDHC1_CD_B
CCM_EXT_CLK3
S107CSI_P2_PWDNP7GPIO1_IO053.3V
M4_NMI
CCM_PMIC_READY
S108SD2_VSELECTP5GPIO1_IO043.3V
USDHC2_VSELECT
SDMA1_EXT_EVENT1
S109GND——————
S110ENET_RD0U19ENET1_RGMII_RD02.5V
GPIO1_IO26
S111ENET_RD0U21ENET1_RGMII_RD02.5V
GPIO1_IO27
S112ENET_RX_CTLT21ENET1_RGMII_RX_CTL2.5V
GPIO1_IO24
S113ENET_RD2U20ENET1_RGMII_RD22.5V
GPIO1_IO28
S114ENET_RD3V19ENET1_RGMII_RD32.5V
GPIO1_IO29
S115ENET_RXCT20ENET1_RGMII_RXC2.5V
ENET1_RX_ER
GPIO1_IO25
S116GND——————
S117ENET_TD1R21ENET1_RGMII_TD12.5V
GPIO1_IO20
S118ENET_TD0R20ENET1_RGMII_TD02.5V
GPIO1_IO21
S119ENET_TD3P20ENET1_RGMII_TD32.5V
GPIO1_IO18
S120ENET_TXCT19ENET1_RGMII_TXC2.5V
ENET1_TX_ER
GPIO1_IO23
S121ENET_TD2R19ENET1_RGMII_TD22.5V
ENET1_TX_CLK
GPIO1_IO19
S122ENET_TX_CTLP19ENET1_RGMII_TX_CTL2.5V
GPIO1_IO22
S123GND——————
S124ENET_MDION19ENET1_MDIO2.5V
GPIO1_IO17
S125ENET_MDCN20ENET1_MDC2.5V
GPIO1_IO16
S126GND——————
S127SDIO_WAKEM21USDHC2_WP3.3V
GPIO2_IO20
S128SD2_DATA2P22USDHC2_DATA23.3V
GPIO2_IO17
S129SD2_NRSTR22USDHC2_RESET_B3.3V
GPIO2_IO1
S130SD2_DATA1N21USDHC2_DATA13.3V
GPIO2_IO16
S131SD2_DATA0N22USDHC2_DATA03.3V
GPIO2_IO15
S132SD2_CMDM22USDHC2_CMD3.3V
GPIO2_IO14
S133SD2_DATA3P21USDHC2_DATA33.3V
GPIO2_IO18
S134SD2_NCDL21USDHC2_CD_B3.3V
GPIO2_IO12
S135GND——————
S136SD2_CLKL22USDHC2_CLK3.3V
GPIO2_IO13
S137GND——————
S138
S139QSPIA_NSS0H19RAWNAND_CE0_B3.3V
QSPI_A_SS0_B
GPIO3_IO01
S140NAND_DATA3J21RAWNAND_DATA033.3V
QSPI_A_DATA3
GPIO3_IO09
S141NAND_DATA1J20RAWNAND_DATA013.3V
QSPI_A_DATA1
GPIO3_IO07
S142NAND_DATA2H22RAWNAND_DATA023.3V
QSPI_A_DATA2
GPIO3_IO08
S143GND——————
S144QSPIA_SCLKG19RAWNAND_ALE3.3V
QSPI_A_SCLK
GPIO3_IO00
S145GND——————
S146NAND_DATA0G20RAWNAND_DATA003.3V
QSPI_A_DATA0
GPIO3_IO06
S147NAND_NREADYK20RAWNAND_READY_B3.3V
GPIO3_IO16
S148NAND_DATA7M19RAWNAND_DATA073.3V
QSPI_B_DATA3
GPIO3_IO13
S149NAND_DATA4L20RAWNAND_DATA043.3V
QSPI_B_DATA0
GPIO3_IO10
S150NAND_NWPK21RAWNAND_WP_B3.3V
GPIO3_IO18
S151NAND_DATA5J22RAWNAND_DATA053.3V
QSPI_B_DATA1
GPIO3_IO11
S152NAND_NWEK22RAWNAND_WE_B3.3V
GPIO3_IO17
S153NAND_NCE3H20RAWNAND_CE3_B3.3V
QSPI_B_SS1_B
GPIO3_IO04
S154BT_DEV_WAKEG21RAWNAND_CE1_B3.3V
QSPI_A_SS1_B
GPIO3_IO02
S155NAND_CLEH21RAWNAND_CLE3.3V
QSPI_B_SCLK
GPIO3_IO05
S156NAND_DATA6L19RAWNAND_DATA063.3V
QSPI_B_DATA2
GPIO3_IO12
S157TCPC_NINTF21RAWNAND_CE2_B3.3V
QSPI_B_SS0_B
GPIO3_IO03
S158GND——————
更多回帖
