你好
我正在尝试在CentOS 7.x上安装GRID 6.0,但除了安装版本7.4之外没有任何运气。
7.4的问题在于它目前不支持Citrix,所以我需要使用早期版本,理想情况是7.3。
我坚持的位是“内核源文件”部分(见附件)。
我可以通过运行“yum update”来解决这个问题,但问题在于它将整个操作系统升级到版本7.4,它修复了GRID安装,但破坏了Citrix。
如果有人可以建议如何解决这个问题,将不胜感激
谢谢
本
以上来自于谷歌翻译
以下为原文
Hi
I'm trying to install GRID 6.0 on CentOS 7.x, but not having any luck apart from version 7.4, which does install. The problem with 7.4, is that it's not currently supported by Citrix, so I need to use an earlier version, ideally 7.3 at this stage.
The bit I'm stuck at is the "Kernel Source Files" part (see attached). I can fix that by running "yum update", but the problem with that is that it upgrades the en
tire OS to version 7.4, which fixes the GRID install, but breaks Citrix.
If anyone can advise how to get around this issue it would be much appreciated
Thanks
Ben
