Microchip
直播中
李滢芝
8年用户 229经验值
私信 关注
[问答]
PicTail Plus扩展板上的SD/MMC卡在哪里插入
刚开始的SD卡工作,但找不到任何简单的信息,在哪里插入卡。我想它像附件中的图片,但是有人能确认吗?
以上来自于百度翻译
      以下为原文
    Just getting started with the SD card work but can't find any simple information about where to plug the card in. I think it goes like in the attached picture but can anyone confirm?
   Attached Image(s)
回帖(5)
张蕾
2018-9-26 09:54:25
HiTe依赖于你正在适应它的董事会。就我几年前所能想到的,我发现了一些关于如何将它连接到我的Pic18 Explorer在Microchip网站上的文档。可能在卡相关文档中。如果你没有找到它,我保证你可以在PICTHED卡上查看PIN功能,并将它与你连接的板上的电路相匹配。如果有一个软件演示,该代码可能会给你一些关于PIC引脚在与卡的通信中使用的提示。还检查SD/MMC主题的任何应用笔记。
以上来自于百度翻译
      以下为原文
    Hi
That depends on the board you are adapting it to.
As far as I can remenber from a few years ago, I found some documentation on how to connect it to my PIC18 Explorer in the Microchip website. Probably on the card related documentation.
If you don't find it, I sugest youi look at the pin functions on the pictail card and mate it with the circuitry on the board you are connecting it to. If there is a software demo, the code might give you some hints on what PIC pins are used in the comunication with the card. Also check for any application notes on the SD/MMC subject.
HIH
Best regards
Jorge
举报
高若琰
2018-9-26 10:12:01
我终于找到了扩展板的示意图,并跟踪线通过PIC引脚。图中所示的取向对于“SPI2”是正确的,并且可以追溯到预期的微PIN。NB。扩展板原理图上的CD和WD(引脚60和62 RESP)都是LabelDelp90,但在Explorer板上是P90和P89(USB)。
以上来自于百度翻译
      以下为原文
    I eventually found the Expansion board schematic and traced the lines through to the PIC pins. The orientation shown in the picture is correct for 'SPI2' and is traceable back to the expected micro pins.
NB. CD and WD (pin 60 and 62 resp') on the expansion board schematic are both labelled P90 but back at the Explorer board they are P90 and P89 (USB).
举报
高若琰
2018-9-26 10:17:21
不要相信照片里的照片,因为这是S/C的力量。SD适配器应该是其他方式,卡片阅读器面对Excel 16/32。
以上来自于百度翻译
      以下为原文
    Don't trust the way I have it in the photo because this s/c the power. SD adaptor should be other way around, card reader facing the Explorer16/32.
举报
张蕾
2018-9-26 10:23:49
HIIS这是你所创立的HTTP://WW1.MICCHIP.COM/DIXBOSS/En/DeVICECDOC/DS-51583B.PDFU卡应该连接到最后一页中的“卡边缘连接器”图。您可以使用PIC引脚指定(RB2/RG9,RF6/RG6,…)和电源线来调整它的位置。在PICTHOP PLUS和Explorer之间使用扩展卡,而不是映射整个路径。顺便问一下,你使用的是Explorer吗?HyHube关于JurrGE
以上来自于百度翻译
      以下为原文
    Hi
Is this what you have found
http://ww1.microchip.com/downloads/en/DeviceDoc/DS-51583b.pdf
Your card should be connecetd acording to the "card edge connector" diagram in the last page.
You can use the PIC pins designations (RB2/RG9, RF6/RG6, ....) and the power lines to adjust its position.
If you are using an expansion card between the pictail plus and the explorer, than you have to map  the whole path.
By the way wich explorer are you using?
HIH
Best regards
Jorge
举报
更多回帖
