工程资源中心
直播中
尹姗姗
8年用户 189经验值
私信 关注
[电源设计]
使用TPS56265产生三个输出轨的POL参考设计包括BOM及层图
            The PMP40041 is a reference design which uses the TPS56265 to generate three output rails. The input voltage range is 4.5V to 14V. The TPS65265 incorporates a triple synchronous buck converter with continuous output current 5A/3A/2A . The PMP40041 has dedicated headers to switch the output voltage  (...)
主要特色
  • Operating input voltage range 4.5V to 14V input
  • 5A/3A/2A output current triple synchronous buck solution
  • Dedicated headers to switch the output voltages among 1.0V, 1.8V and 3.3V
  • Forced continuous current mode (FCCM)
  • Size 22mm*18mm for main power circuit
更多回帖
