工程资源中心
直播中
沈艳丽
8年用户 151经验值
私信 关注
[电机控制]
用于HVAC散热孔和电机控制的可配置步进驱动器包括BOM及层图
            This reference design provides a flexible stepper motor system designed to drive up to two stepper motors, or 8 peripherals, while reducing the number of GPIOs needed from the host controller reducing overall cost. The system is suitable for applications requiring stepper motors or coils up to 50V  (...)
主要特色
  • Subsystem Adaptable to a Wide Range of Building Automation Applications
  • Only 3 GPIO Pins Required to Drive Any Multiple of 8 Channels
  • Expandable to Desired Number of Drive Channels
  • Adaptable across a wide range of drive applications - stepper motors, relays, LEDs
  • High-Voltage (up to 50V), High-Current  (...)
更多回帖
