英伟达
直播中
姜雨孜
7年用户 195经验值
私信 关注
[问答]
旧的K2卡被动冷却与戴尔Poweredge T630是否兼容
问题我们有一些旧的K2卡被动冷却。
我被告知他们与戴尔Poweredge T630兼容是否与R730兼容?
谢谢
以上来自于谷歌翻译
以下为原文
Question we have some older K2 cards that are passively cooled. I'm told they are not compatible with the Dell Poweredge T630 are they compatible with the R730s? Thank you
回帖(6)
李琴
2018-9-21 11:38:12
如果使用VMware / Citrix,则需要检查相应的虚拟机管理程序HCL。
如果GRID是phsyical的NVIDIA认证列表。
此KB上的参考部分包含上述所有内容的链接:http://nvidia.custhelp.com/app/answers/detail/a_id/4122
任何问题都会回来询问(甚至让我们知道你找到了你需要的信息!)
这也可能有用/兴趣:http://nvidia.custhelp.com/app/answers/detail/a_id/4116/kw/supported%20vsphere
最好的祝愿,
雷切尔
以上来自于谷歌翻译
以下为原文
If using VMware/Citrix you need to check appropriate hypervisor HCL. If GRID phsyical the NVIDIA certified list.
The reference section on this KB has links to all of the above: http://nvidia.custhelp.com/app/answers/detail/a_id/4122
Any questions do come back and ask (or even let us know you found the info you needed!)
This might also be of use/interest: http://nvidia.custhelp.com/app/answers/detail/a_id/4116/kw/supported%20vsphere
Best wishes,
Rachel
举报
李慧
2018-9-21 11:46:35
嗨Rachel,我发现一个戴尔论坛帖子似乎表明它很好。
我们正在做vGPU,不确定这是否有所不同,因为这个兼容性矩阵适用于vDGA?
以上来自于谷歌翻译
以下为原文
Hi Rachel, I found a Dell forum post that seemed to indicate it was good. We are doing vGPU not sure if that makes a difference since this compatibility matrix is for vDGA?
举报
王辉
2018-9-21 11:57:01
不要把它当作事实,但我有一台T630,这些卡是主动冷却的,附加支架上有2个小风扇。
由于该机箱的散热设计,它需要戴尔称之为A版本(K2A)。
我相信R730使用普通的K2(无源)冷却卡,如HP DL380 G8 / G9,这取决于机箱本身的气流和设计。
这是我根据研究和戴尔谈判时的理解,当我们在T630和R730之间做出决定并试图弄清楚我们需要什么卡/如果我们可以重复使用我们现有的被动冷却K2卡。
以上来自于谷歌翻译
以下为原文
Don't take this as fact, but I have a T630 and those cards are actively cooled with an additional bracket with 2 small fans on it.  Because of the cooling design of that chassis it requires the A version as dell calls them (K2A).  I believe the R730 uses the normal K2 (passive) cooled cards like the HP DL380 G8/G9 which depends on the airflow and design of the chassis itself.
This is my understanding based on research and talking to Dell when we were deciding between the T630 and R730 and trying to figure out what cards we needed/if we could reuse our existing passively cooled K2 card.
举报
王建华
2018-9-21 12:07:15
VMware GRID vGPU常见问题解答(有关经过认证的服务器部分):http://www.vmware.com/files/pdf/products/horizo​​n/vmware-nvidia-grid-vgpu-FAQ.pdf
以上来自于谷歌翻译
以下为原文
VMware GRID vGPU FAQs (section on certified servers): http://www.vmware.com/files/pdf/products/horizon/vmware-nvidia-grid-vgpu-FAQ.pdf
举报
更多回帖
