工程资源中心
直播中
刘建国
8年用户 204经验值
私信 关注
[电源设计]
10V至32V输入,25V/1A输出的4开关降压/升压控制器包括BOM及层图
            PMP20430 is a 4-switch buck-boost controller utilizing the LM5175 for industrial applications. This design has a minimum operating input voltage of 10V and a maximum input voltage of 32V, supports 25Vout @ 1A.  Switching frequency is set to 600kHz, during buck-boost mode, switching frequency  (...)
主要特色
  • 10V to 32V in, output 25V @ 1A
  • Achieving efficiency of 90% across entire operation range, 96% peak efficiency
  • Compact size, slim form factor
  • Solution size:  24mm x 20mm
  • LM5175 4-switch buck-boost controller, wide Vin, high efficiency
更多回帖
