PMP15007 uses the LM5161-Q1 in a Fly-Buck topology with the primary and secondary output both set to 5V nominal. The circuit accommodates a voltage input range from 36V to 72V, ideal for the 48V nominal input rail. While the primary side is set at 5.32V nominally, the secondary isolated side sees 5V (...)
主要特色
36V to 72Vin, 5V @225mA (dual) output, 2.25W (one non-isolated primary and one isolated secondary)
~75% peak efficiency
Compact and cost effective isolated solution with an off-the-shelf coupled inductor instead of custom transformer
Solution size: 32 mm x 22 mm (1.25 in. x 0.9 in.); max component (...)
