Qualcomm技术论坛
直播中
刘丽
7年用户 1261经验值
私信 关注
[经验]
从SD卡中加载Dataset
从SD卡中加载Dataset
AR/VR技术交流群 129340649
1、使用Vuforia
For unity SDK中Dataset
abstract bool Load
(String name)
默认从"StreamingAssets/QCAR" 加载.
abstract bool Load
(String path, VuforiaUnity.StorageType storageType)
从给定路径加载Dataset,storageType说明路径类型。
STORAGE_APP, STORAGE_APPRESOURCE, STORAGE_ABSOLUTE
2、
从SD卡中加载Dataset数据
复制代码
[size=1em]
1
[size=1em]
2
[size=1em]
3
[size=1em]
4
[size=1em]
5
[size=1em]
6
[size=1em]
7
[size=1em]
8
[size=1em]
9
[size=1em]
10
[size=1em]
11
[size=1em]
12
[size=1em]
13
[size=1em]
14
[size=1em]
15
[size=1em]
16
[size=1em]
17
[size=1em]
18
[size=1em]
19
[size=1em]
[size=1em]
21
[size=1em]
22
[size=1em]
23
[size=1em]
24
[size=1em]
25
[size=1em]
26
[size=1em]
27
[size=1em]
28
[size=1em]
29
[size=1em]
30
[size=1em]
31
[size=1em]
32
[size=1em]
33
[size=1em]
34
[size=1em]
35
[size=1em]
36
[size=1em]
37
[size=1em]
38
[size=1em]
39
[size=1em]
40
[size=1em]
41
[size=1em]
42
[size=1em]
43
[size=1em]
44
[size=1em]
45
[size=1em]
46
[size=1em]
47
[size=1em]
48
[size=1em]
49
[size=1em]
50
[size=1em]
51
[size=1em]
52
[size=1em]
53
[size=1em]
54
[size=1em]
55
[size=1em]
56
[size=1em]
57
[size=1em]
58
[size=1em]
59
[size=1em]
60
[size=1em]
61
[size=1em]
62
[size=1em]
63
[size=1em]
64
[size=1em]
65
[size=1em]
66
[size=1em]
67
[size=1em]
[size=1em]
using UnityEngine;
[size=1em]
[size=1em]
using Vuforia;
[size=1em]
[size=1em]
using System.Collections;
[size=1em]
[size=1em]
using System.Collections.Generic;
[size=1em]
[size=1em]
[size=1em]
[size=1em]
public class SDCardDataSetLoader
: MonoBehaviour
[size=1em]
[size=1em]
[size=1em]
[size=1em]
    private bool mLoaded
= false;
[size=1em]
[size=1em]
    private DataSet
mDataset = null;
[size=1em]
[size=1em]
Update is called once per frame
[size=1em]
[size=1em]
    void Update()
[size=1em]
[size=1em]
[size=1em]
[size=1em]
        if (VuforiaRuntimeUtilities.IsVuforiaEnabled()
&& !mLoaded)
[size=1em]
[size=1em]
[size=1em]
[size=1em]
            string externalPath
= "/mnt/sdcard/tARMac.xml";
[size=1em]
[size=1em]
[size=1em]
[size=1em]
            if (mDataset
== null)
[size=1em]
[size=1em]
[size=1em]
[size=1em]
First, create the dataset
[size=1em]
[size=1em]
                ObjectTracker
tracker = TrackerManager.Instance.GetTracker();
[size=1em]
[size=1em]
                mDataset
= tracker.CreateDataSet();
[size=1em]
[size=1em]
[size=1em]
[size=1em]
[size=1em]
[size=1em]
            if (mDataset.Load(externalPath,
VuforiaUnity.StorageType.STORAGE_ABSOLUTE))
[size=1em]
[size=1em]
[size=1em]
[size=1em]
                mLoaded
= true;
[size=1em]
[size=1em]
[size=1em]
[size=1em]
            else
[size=1em]
[size=1em]
[size=1em]
[size=1em]
                Debug.LogError("Failed
to load dataset!");
[size=1em]
[size=1em]
[size=1em]
[size=1em]
[size=1em]
[size=1em]
[size=1em]
[size=1em]
路径设置:
首先需要开启对SD卡的读写权限。在Unity3d中,可以在Player
Settings中设置,如下:
或者在AndroidManifest.xml中进行设置。
其次设置路径:
大部分手机SD卡的路径如下:
/mnt/sdcard/
也有部分手机SD卡路径如下:
/sdcard
/storage/sdcard0
或者使用externalPath = Application.persistentDataPath;
当你开启了权限之后,该路径如下:
/storage/sdcard0/Android/data/ + + /files
假如你的包名为com.arvrschool.apps,那么该路径即为:
/storage/sdcard0/Android/data/com.arvrschool.apps/files
那么保存的dataset的完整路径可表示如下:
/storage/sdcard0/Android/data/com.arvrschool.apps/files/tarmac.xml
/storage/sdcard0/Android/data/com.arvrschool.apps/files/tarmac.dat
更多回帖
