导致GRID Test Drive出现连接问题的最常见问题之一是防火墙上的端口和协议阻塞。
请使用Telnet或类似工具确认端口访问。
您需要打开的端口是:
47991,47995,47996,47998,47999,48000,35043,42231,443和5001
需要为UDP和TCP流量启用这些端口。
以上来自于谷歌翻译
以下为原文
One of the most common issues causing connec
tivity problems with GRID Test Drive is port and protocol blocking at your firewall. Please use Telnet or a similar tool to confirm port access.
The ports you’ll need opened are:
47991, 47995, 47996, 47998, 47999, 48000, 35043, 42231, 443 and 5001
These ports need to be enabled for both UDP and TCP traffic.
